Increased Air intake to the Supercharger
Rating: Thread Rating: 3 votes, 5.00 average.
Old 12-30-2008, 12:23 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by itsmeek
I don't see any gains from this mod, as a previous poster mentioned- you're blocking your radiator for a small gain to the intake. I've seen projects like this several times in turbo apps (supras, dsm's, etc) w/large intercoolers that blocked the radiators and the results were pretty detrimental to the cars cooling system. I would think for this mod a large puller fan would be needed to offset the decrease in airflow.
did you do this mod or are you just speculating?
our cars don't have cooling problems so imho, minimally blocking the radiator is of insignificant concern. many of us spend thousands for small gains in performance and this is a FREE mod (if you make your own) that seems to have given me a tenth in the 1/4mile even though i too didn't believe f/i cars would benefit from it.
Old 12-30-2008, 12:41 PM
E55Pilot's Avatar
2004 E55
The reason large intercoolers impacted to cooling system is due to the fact that they were prewarming the air before it got to the radiator reducing it's efficiency.
Those intakes flaps are going to do nothing to impact the cooling system on the E55.
Old 12-30-2008, 12:45 PM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
I have done so on a few other cars and seen it on many others with comparable results.
Old 12-30-2008, 12:46 PM
itsmeek's Avatar
Perhaps some prewarming but it's actually because of restricted airflow. This is why larger cfm puller fans help to remedy the issue.
However I am not an expert on this stuff and will never claim to be. My z06's all had vararam intakes on them that I installed and it seemed to help them gain up to 20hp.
OXOJE55's Avatar
///AMG
Will these ran intake be better in CF so they will not heat up
Were can I buy them
Old 12-30-2008, 01:17 PM
blackbenzz's Avatar
haters crazy
I will test my setup next year, I can swap back to stock inlets in a matter of minutes. Unfortunately there are no drag strips open here for a few more months
Old 12-30-2008, 01:23 PM
  #32
itsmeek's Avatar
Your car is SICK.
Old 12-30-2008, 01:28 PM
  #33
blackbenzz's Avatar
haters crazy
Your car is SICK.
Thanks!
Old 12-30-2008, 01:30 PM
  #34
chiromikey's Avatar
Were can I buy them
cf will not make any difference since they're ahead of anything in the engine bay that would heat them up.
seriously, on the next rainy saturday morning, make your own for the cost of scrap sheet metal and spray paint rather than pay a company $250 for them.
Old 12-30-2008, 01:33 PM
  #35
OXOJE55's Avatar
///AMG
Thanks,
Old 12-30-2008, 01:48 PM
  #36
jangy's Avatar
2015 S212
I can attest to the car running stronger with the grill taken off. i dunno if that is restriction or RAM air, but maybe the two go a little hand in hand.
I get that RAM systems don't usually help our cause since we pull in our air, but what if we just consider the pre-filter portion of the intake? Could the RAM Air not be helping to overcome some of the restriction that we see in the piping from the mouth? In a way, wouldn't it sort of be the opposite of raising elevation, since it is increasing local pressure?
My main concern with this mod has been worrying about the motor cooling but we are getting some word that it may not be quite the issue.
All of this really tells me that the mouth needs to be wider. I've been dying to dremel the plastic frame of the radiator to allow a 3" tube through but I need to make sure the radiator stays solid. Worst case, I could pull it out and modify it. we have very little room on these cars and my only real choices are to run the tubes down to the fog light area or find a larger hole where they are. IMO, Ahmed's mod is the ideal.
Old 12-30-2008, 02:00 PM
  #37
NXtremeJeep's Avatar
GT-R
What about this? I believe it's a Renntech piece.
Old 12-30-2008, 02:37 PM
  #38
jangy's Avatar
2015 S212
I have never seen the piece, but i have my stuff pulled out and that would definitely work. also, that part of the hood is a high pressure area so air would tend to come in. I just always wondered how hard to would be to fab something like that. We will see very soon
Old 12-30-2008, 02:41 PM
  #39
E55Pilot's Avatar
2004 E55
You have data to back up that claim?
The grille is not going to be a intake restriction
Old 12-30-2008, 03:41 PM
  #40
jangy's Avatar
2015 S212
Data that is documented and verified? No. Consistently running 1/10th faster in the quarter, yes. I don't want to argue with. Lets be productive. That doesn't mean I am right. It means please explain why you think not. BTW, this has been shown on more than just the E55....
Old 12-30-2008, 04:00 PM
  #41
E55Pilot's Avatar
2004 E55
1/10th could be air density.
Take the total area of all the grilles that feed the radiator/air intake, now compute the shadow area of the grille (The blockage). now as long as you have more than 16 square inches open then you will have zero grille restriction. (That's using rough rules of thumb, the required area is actually much smaller)
So no removing the grille will not cause you to feel that the car is running harder (You won't feel 1/10th...)
Old 12-30-2008, 04:02 PM
  #42
chiromikey's Avatar
i modified my grill at the same time i made my intake scoops so how much it's worth, i don't know...but there is at least a bit of restriction with the oem grill. if you look on the passenger side of the grill you can see where the slits are actually closed off right in front of the intake opening.
Old 12-30-2008, 04:06 PM
  #43
blackbenzz's Avatar
haters crazy
Its even worse on the CLK. Not only is the grille blocked off on both sides, the hood closes directly in front of both inlets! What was MB thinking?
If someone local doesn't mind losing their high beams and having holes in their headlights I can try to make them the same setup as mine. Get before/after dynos and 1/4 numbers. If you guys just want dyno numbers I can probably get that done pretty soon. One pull with stock inlet location (hood closed) and one with headlight intakes
Old 12-30-2008, 04:07 PM
  #44
E55Pilot's Avatar
2004 E55
it's easy to see if there is a restriction, just run a differential pressure gauge next to the snorkel and the other side of the gauge somewhere under the hood near the abs block (That looks like a good place to grab static pressure)
Do it with and without the grille. You're not going to see a difference
Old 12-30-2008, 04:41 PM
  #45
chiromikey's Avatar
the e is the same. also the oem ducts have a nice restrictive cage around the entire inlet.
Old 12-30-2008, 04:44 PM
  #46
E55Pilot's Avatar
2004 E55
That's actually part of the Helmholtz tuning to keep the intake quiet.
Guys you seem to be forgetting that the largest restriction in the intake is the throttle body.
Old 12-30-2008, 05:48 PM
  #47
jangy's Avatar
2015 S212
Plus keeping water out during rains. Many if not all of us tear that off first thing.
as you would say, DING DING!! many here don't believe the 80mmTB is still too small.
Old 12-30-2008, 05:59 PM
  #48
chiromikey's Avatar
unfortunately, removing that had zero effect on intake noise.
also, i'm not forgetting the tb...i've already opened it up as far as the market will allow at this point so i'm simply moving to other areas that are easier to deal with.
Old 12-31-2008, 09:42 AM
  #49
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
yes, I think it was their second best choice when they had to locate somewhere the intake duct after install of top mounted intercoolers (SLR style).
high pressure air will enter there only after removal of the grill in the hood
.. i think it is nothing to be emulated if you are not planning a scoop install
Old 12-31-2008, 10:01 AM
  #50
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
I was thinking about doing this myself... looking to extend the airflow pipes down into the bottom section of the bumper by the fog lights or the center mesh, much like you see on some BMWs
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Increased Air intake to the Supercharger
