MHP 180F 63 Thermostats Now Available
Old Nov 14, 2008 | 03:03 PM
MHP's Avatar
MHP
'09 C63 AMG
MHP is now offering modified stock/MB (180F open temperature) Thermostats.
The primary benefits of a lower open temperature thermostat are the consistant performance and increased engine engine life. The relatively high open temp stock thermostat assures reduced emissions and therefore isn't optimal for performance applications as the ECU pulls timing when seeing higher ECTs (Engine Coolant Temps).
Lower coolant temps equate to increased engine longevity/durability and allow us to use more aggressive timing tables when custom ECU or ECU/TCU tuning, though even when stock the OEM ECU calibration won't have to pull as much (if any) timing due to heat soak--equating to more consistant performance. Next to detonation/preignition and excessive rpm, heat is the next largest killer of engines.
Real world testing with our own C63 has shown significant reductions in ECTs, 15-25F less depending on application, environment, and driving situation. With the OEM/stock Thermostat we averaged 194-204F ECTs while cruising at 75-80mph. Post MHP T-stat install, we see a consistant 174-180F at the same speed. We also have not witnessed the coolant temp rise above 194F, even after hard WOT beatings, and in stop and go traffic.
When paired with our ECU or ECU/TCU tuning, which turns the cooling fans on earlier, the heatsoak issue with 63s is completely resolved.
Price is $279.99 shipped in the Continental U.S. via UPS/FedEx Ground.
Old Nov 14, 2008 | 04:11 PM
RENNSTAGE's Avatar
il take 6
Old Nov 15, 2008 | 12:57 AM
rarfinancial's Avatar
CLS63
Damn Andy
Old Nov 15, 2008 | 01:17 AM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Congrats on your first sticky !!!
Old Nov 15, 2008 | 02:13 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
thermostats
do you make or can you make a thermostat for an 03 sl 500 that has a kleeman supercharger on it
Old Dec 3, 2008 | 07:23 AM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
Isn't the thermostat WITHOUT the ECU/TCU pretty mush useless? Even though the stat opens up early it would still reach the same operating temp..will just take a little longer.
Old Dec 3, 2008 | 01:19 PM
MHP's Avatar
MHP
'09 C63 AMG
Far from useless. The stat will open sooner than a stocker which is most notable on the highway or while cruising. In stop and go you really need the ECU tuning to get the fans on earlier as well.
Old Dec 8, 2008 | 01:27 AM
CLS63
Installed mine today ( Sunday Dec 07, 2008 ) Easy install with know problems. Thanks Andy,
Old Dec 8, 2008 | 10:08 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
I recieved my too, but where the hell is the t-stat on these cars?
Old Dec 8, 2008 | 01:15 PM
CLS63
Take off the engine cover, look for the slot where the engine cover front clip clips in, move all that crap and have fun, you don't need to remove it all just move it out of the way. Follow the radiator hose there and you will see it.
Old Dec 8, 2008 | 01:21 PM
jrcart's Avatar
Sounds like a job for the Mercedes dealership...LOL
Old Dec 8, 2008 | 01:26 PM
CLS63
LOL, looks harder than it is. Hey keep your eyes posted on the night of the 13th there should be some good #'s oh, and Juicee won't be to happt either
Old Dec 8, 2008 | 01:36 PM
jrcart's Avatar
I can't wait...I hope you guys both break well into the 11's. Good Luck I'll be watching.
Old Dec 9, 2008 | 11:35 AM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
I think book is about 2 hours on it, it took us roughly an hour or so. Also don't forget to refill the coolant.
On a level of 1 to 10, I'd call it a 1.5. Once you see where the thermostat is then the battle is over.
good luck
Old Dec 9, 2008 | 11:41 AM
CLS63
good luck
If anyone needs a great shop for Mods or installs Give James a call. He has my two James@ACGSD He saiD COOLANT
Old Jan 30, 2009 | 12:53 AM
jpohl402's Avatar
E55 then E63, now back to an E55
Any more experience with these?
Old Feb 3, 2009 | 01:08 AM
veightkiller's Avatar
335i e90 / C63 / R6
can you DIY this one?
Old Feb 3, 2009 | 01:35 AM
CLS63
Run after run at the track ,my car by far stays cooler than the others..
Old Feb 3, 2009 | 05:50 AM
Fr33kn63's Avatar
E63 AMG
I got one of these but just one more part I havent had a chance to install yet Looking forward to hopefully the engine staying a little cooler!
Old Feb 3, 2009 | 03:32 PM
MHP's Avatar
MHP
'09 C63 AMG
Sorry, the image isn't working.
Andy
Old Mar 6, 2009 | 10:04 PM
KKKMMM's Avatar
LEXUS XP
Brass air fittig
HELLO!!!
Now that is a lot of brass air fittings there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo bu
THANK YOU .
