Renntech mods
Renntech mods
I have a Renntech Throttle Body and some Renntech Headers I've had for about a year and never installed(2005 E55). I'm going to install them soon and would like to know if it is necessary to reprogram the ECU also. I already have the RT pulley with RT programming on the car. Will it hurt anything to drive it for a while without reprogramming again? I plan on having the ECU remapped at some time but it is just not convenient at this time.
Super Moderator
I think you will be okay...but you won't be able to take full advantage of the headers and the TB without that tune...
I'm only a n00b so I'm sure someone can correct me if I'm wrong...
W220 S65 AMG
You will ABSOLUTELY need a new ECU program with the larger throttle body and headers. The car will be running very lean, feel very fast but it will not be safe for any extended period of time.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Thanks for the info. The problem is that the car will only be in the shop a day or two and I will have to pick it up. This isn't enough time to send my ECU to Renntech. Its about 10 miles from my house to the shop so I need to get the car back home and then send off the ECU. I assume this would be OK?
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
This is what we doing for one of our customer who is install Kleemann headers, drop the car off, we'll rack it today, even tho we won't start until tomorrow, pull the ecu and overnight it today. Then just have RENNtech overnight am delivery for you and your shop will have the reprogrammed ECU by 8-10am in the morning.
Hope this helps.
Seems like I see conflicting info on this. In another thread someone is running a larger pulley than the Renntech and also an 80mm throttlebody with seemingly no ill effects, so why would I need a tune just to drive the car 10 miles?
2015 S212
You can add a TB and headers without any adjustment in tune and your car will be fine. I wish i could get this thing to run lean. You already have an RT tune, so your pulley should be performing. Either way, even if not optimal your car will be fine to drive forever much less 10 miles. I'm still waiting to see some data from a new RennTech tune that shows TQ management control.
2015 S212
Talk to your shop and see if you could leave it there for an extra day.
Hope this helps.
Hope this helps.
CLS63
2015 S212
3? Wait, what happened? Give me a link, if you posted it. I knew about the OEM one, then a new one that MHP was to flash. Let me guess, got the 3rd to retire the original? How long does it take and how involved is swapping it out?
CLS63
The Renntech ECU, which is still good, the new stock ECU, that is in my car now will be sent to Andy in the morning and the noncoded ECU, that will get coded this coming week and stay stock. The R&R is about 10 minutes tops..
