Racing 60-130 mph?
Old 03-02-2009, 03:36 PM
blackbenzz's Avatar
haters crazy
Originally Posted by TMC M5
Here is a 60-130mph (8.45s) I ran a couple of weeks ago. I will be using my pbox at the next MIR rental (hopefully on Wednesday). It will be interesting to measure some more GPS based 1/8 and 1/4 mile times and traps compared to the timing equipment.
Tom
You have a pbox? You've been holdin out on me!!!
Old 03-02-2009, 03:43 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I thought you knew! Jay borrowed it back in November at the last event. My bad. You can borrow it at the track. Maybe it would make sense if you brought your own SD memory card so you can take it with you and download. You can download the software free online to analyze the data.
http://www.vboxusa.com/performancedr...ormancebox.php
Tom
Old 03-02-2009, 04:27 PM
blackbenzz's Avatar
haters crazy
Tom
Awesome, thanks!
Old 03-26-2009, 02:34 AM
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
Whats with the no nitrous pride? just run nitrous, ZOOM!
Old 03-26-2009, 01:16 PM
Max.H's Avatar
E55
If the M5 can do it in 10.4 secs. Then the 55/63 should be about the same. I dunno about 10.9 secs . Maybe the person left it in automatic and wasted time when the tranny kicked down.
Old 03-26-2009, 01:36 PM
TMC M5's Avatar
That 10.9s time on the E63 was done by Aaron Cicchelli (member of 6speedonline and mbworld). He is pretty much a master of the 60-130mph times. He was able to get his RENNtech SL65 to a 7.48s time (unbelievably fast), his stock SLR to 7.24 and his now RENNteched SLR to 6.65s....I wouldn't question his driving abilities. He may not have run the E63 on an optimal day weather wise. There is a 100+ page thread on 6speedonline with all the times. He usually is pretty informative as to weather conditions...if you are so inclined to research that.
Tom
Old 03-26-2009, 02:16 PM
  #32
regor60's Avatar
06 E55 Black
10.9 is on the far edge of credibility for a stock E63 60-130, given the data out there. 12 seconds is more like it
Old 03-26-2009, 02:24 PM
  #33
JAYCL600's Avatar
new balance
Originally Posted by regor60
10.9 is on the far edge of credibility for a stock E63 0-130, given the data out there. 12 seconds is more like it
its 60-130
Old 03-26-2009, 02:28 PM
  #34
regor60's Avatar
06 E55 Black
Originally Posted by JAYCL600
its 60-130
gotcha, correct data though. fixed post
Old 03-26-2009, 03:14 PM
  #35
TMC M5's Avatar
Car & Driver did 0-130mph of a stock E63 in 16.1s. If you subtracted out the 0-60mph time of 4.2s you would be right on the money (11.9s 60-130mph). So I can see where you are coming from, but I think you need to take into account a couple of other variables:
1. Weather and road conditions
2. Optimization of gearing
3. Specific car
1. I am not sure what conditions Aaron's times were run under, but C&D did it in the following: 48 deg WET, 62 deg DRY Baro. 27.4 RH 35.7. C&D weather corrects its times. So their test of the E63 (given those conditions) would have corrected the timed #'s up because those were better than their "standard" correction condition. (see attached test sheet top).
2. Aaron being the master at 60-130mph optimizes the gear for a 60-130mph run. He may start the car in a higher gear to avoid an additional shift. Although the car may not seem like it is going faster at first can cut off as much as 1/2 a second by doing this optimization (obviously depending on the car's gearing and shifting speed).
3. The specific car C&D tested had only 1,546 miles. It seems like most performance cars today need some mileage to loosen up the engine a bit.
Tom
File Type: pdf
Quick Reply: Racing 60-130 mph?
