Quick dyno question
I searched dyno mode and printed out procedures.. I then made sure back tires are aired up close to max PSI. I also worked the speed up slowly on the dyno (keep it cool) and then in 4th gear hit the gas at about 3600 rpm..
I am sure others know tricks to maybe dyno from a lower rpm but that his where I stabed it at..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Did you have a chance to fit the heat exchanger before the dyno?
As for HE and CM30, I'm having that installed tomorrow. My tech will be doing my tranny service, HE, CM30, alignment, balancing, and -10 mod. I also have the PTE T-Stat coming in but that won't be here until Monday. The only thing I have left in the engine compartment is to split the circuit.
I'm also considering doing the ECU reset before the dyno run, what do you guys think? Probably doesn't make a difference but just thought I would do it for shiits and giggles.
