HID Fogs Problem
Old Dec 28, 2008 | 05:01 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
HID Fogs Problem
i just treid to install a hid kit in my fogs only one side light up and the drvier side only flashes. i have added the capacitors.
can anybody help? does it need a resister?
thanks
Old Dec 28, 2008 | 09:36 PM
e1000's Avatar
a quarter mile at a time
what size capacitor? Did you get the polarity correct?
Old Dec 28, 2008 | 11:08 PM
shardul's Avatar
35 watt ones. yeah polarity is correct. the direction the arrow on the capacitor faces is the negative terminal.
Old Dec 28, 2008 | 11:37 PM
nikkatine's Avatar
2003 e320
Move to a larger capacitor and it should be fine. I had the same problem before. It may still flash once in a while, flicker actually, but it will work. I ended up using a MTEC kit instead, no problems since.
Old Dec 28, 2008 | 11:56 PM
shardul's Avatar
well one light works and the other one just turns on and off. are you sure a higher wattage capacitor will work. this is the link i followed.
https://mbworld.org/forums/e-class-w...es-models.html
Old Dec 28, 2008 | 11:57 PM
stonedjoseph's Avatar
2007 BMW 328
a much higher capacitor will do the job..
Old Dec 29, 2008 | 12:11 AM
shardul's Avatar
what wattage capacitor should i get?
Old Dec 29, 2008 | 12:12 AM
shardul's Avatar
also why is only that one side works and the other side turns on and off
Old Dec 29, 2008 | 08:59 AM
e1000's Avatar
Funny thing about Mercedes wiring, one side is less tolerant than the other.
It's not just the wattage. What farad rating are you using? Try a 35w 4700uf capacitor.
Old Dec 29, 2008 | 09:43 AM
shardul's Avatar
i am using a 35w 2200uf capacitor
Old Dec 29, 2008 | 09:48 AM
e1000's Avatar
yeah try the 4700uf. If you really want to go big, use a 50w 4700uf cap.
Old Dec 29, 2008 | 10:01 AM
shardul's Avatar
thank you sir will try that
Old Dec 29, 2008 | 11:34 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
LED/HID guru...
Old Dec 29, 2008 | 03:12 PM
e1000's Avatar
Originally Posted by MJ50
LED/HID guru...
