How do you read the dip stick?
Btw, does anyone know whether the E63 has both a "too much oil" and a "too little oil" dashboard warning?
I know similar questions have been asked in the past, but I don't think a good answer has been posted. Thx in advance.
I've generally had better results when checking oil after a drive.
1) let the car sit overnight and check the (cold)level before starting the car
2) drive the car until it's warm and when you get home turn the engine off and wait 5 minutes.........then check the oil level
Great advice- definitely forgot to mention to wait about 5 minutes. I've worked on mostly motorcycles and was always taught also to not rev the motor as it causes the oil pump to pump more oil into the top end thus causing it to take longer to drain...not sure if that's the case on these cars or not but it's something to keep in mind. You should get a good reading after waiting a few minutes, regardless.
