Position of X-Pipe important?
Old Jan 3, 2009 | 06:14 PM
Benz-O-Rama's Avatar
Originally Posted by E55Pilot
Actually don't just have them insert a x-pipe anywhere it's very easy to figure out where it goes.
Straight pipe your cat/resonator delete, then apply some spray paint to the hot pipes, where it burns off first is where you locate your X/H pipe
Holy crap. Who would've known to do something like this? Good info. Let me pose this question to you:
1. Let's say my installer isn't as informed as you about exhaust engineering and dynamics. They install the x-pipe at a less than perfect location. Given that my car is N/A and not really making a whole lot of HP/TQ, can the placement of this x-pipe cause a severe hp/tq degradation? Conversely, can an exactly perfect location of the install, cause an increase in hp/tq on my N/A 5.0 engine?
Old Jan 3, 2009 | 06:26 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Originally Posted by jrcart
If I am not mistaken the best way to determine the location of the "X" is to run straight pipes all the way back, run the car and then take some infared temps of the straight pipes, the point at which it is the hottest is where you cut the pipe and fabricate your "X". This is the way several tuners/shops have done some of my cars that way and if I'mnot mistaken that is how Evosport does theirs too.
Explain why at the hottest point
Old Jan 3, 2009 | 06:47 PM
rarfinancial's Avatar
CLS63
Hurry, Someone knows the how to for H/X pipes. Jim is right that method has been us since the very first H pipes were installed... ding, ding, ding, What do we have for him Jonny......
E55Pilot's Avatar
2004 E55
I said the same thing, on eaiser
Old Jan 3, 2009 | 06:51 PM
Yes you did but do you know why the hottest point?
Old Jan 3, 2009 | 06:54 PM
E55Pilot's Avatar
2004 E55
That where the Highest dynamic pressure is in the exhaust
Old Jan 3, 2009 | 06:59 PM
  #32
E55Pilot's Avatar
2004 E55
Yes you can gain some HP/TQ with an X/H Pipe and you probably will (5-8hp)
Old Jan 3, 2009 | 07:19 PM
  #33
jangy's Avatar
2015 S212
I'm digging that. I'd be curious where the 55k likes it most??
Old Jan 3, 2009 | 07:22 PM
  #34
jangy's Avatar
2015 S212
This is true, we just have not really had a good enough test to show 5hp difference on a dyno.
BTW, E55Pilot did say the same thing with easier method...
Old Jan 3, 2009 | 07:24 PM
  #35
jangy's Avatar
2015 S212
ANyone who has tuned any V-8 knows and understands that X/H pipes are a good thing and another tuning tool.
I know that and don't disagree. Controversy has always been how much of a gain and what design, etc.
The bigger question is what is a non aspriated motor? Electric?
Electric? Dude, it is a motor that has not yet been aspriated......DUUUH!
Old Jan 3, 2009 | 07:25 PM
  #36
jangy's Avatar
2015 S212
On a 300hp car? Hmmm, I dunno about that. I don't think we get much more than 5hp (1%). Would the E500 gain more %wise?
Old Jan 3, 2009 | 07:29 PM
  #37
WHOA! WHOA! WHOA! Just hold on, right there....
318HP.....I have an ECU tune.
Old Jan 3, 2009 | 07:31 PM
  #38
jangy's Avatar
2015 S212
HAHA!! Dude I forgot. I forgot!! Any headers? VRP has them....
Old Jan 3, 2009 | 11:55 PM
  #39
bobgodd's Avatar
2004 E55
It has to do with resonance and limiting it in the exhaust. The entire purpose of an exhaust system in a car is to scavenge exhaust away from the combustion chamber, i.e. helping the engine expel its exhaust fumes as efficiently as possible. Resonance in an exhaust system prohibits maximum efficiency, and thats why placing x/h pipes at the optimum spots in an exhaust system helps to quell exhaust resonance.
I could not find a good reference relating to automotive exhaust, but this article touches on some issues that can be related to automotive exhaust: http://en.wikipedia.org/wiki/Resonance
Old Jan 4, 2009 | 12:09 PM
  #40
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
You did say the same thing, only one problem, your method might be easier, but far less scientific and exact. The "old school" method of hitting the pipe with some flat black Krylon works, but it does not account for things such as how thick the paint is being applied, if you have even slightly thinner coverege in an area it will begin to burn off before an area with thicker/heavier coverage which may or may not be the "hottest" spot. The infared laser thermo gauge is the correct way and only way to do it on a $50k-$150k AMG. Most good tunners/shops have them in there shop because they are used for many many things, I could go into it but don't want to go to off topic. Lets just put it this way, if your shop doing your X-pipe does not have one, you probably don't want them touching ANYTHING on your car.
Old Jan 4, 2009 | 01:10 PM
  #41
NCE500's Avatar
2007 E63, 2006 C55
RE: X-Pipe
If it were me, I would put the X-Pipe where the OEM resonator was, if for no other reason than the engineers used that location to achieve the same purpose. Moving it up or back may or may not materially matter, but why chance it?
For what it's worth, a 13.49 from an E500 ain't bad.
Old Jan 4, 2009 | 01:30 PM
  #42
E55Pilot's Avatar
2004 E55
Bull****. Let's keep the **** waving down to a minimum, Paint or IR will tell you the same spot, it's not magic, it's been done for 50+ years.
My shop has IR probes and surface temp probes and we still use paint, Why? Because it marks the spot.
Old Jan 4, 2009 | 01:31 PM
  #43
E55Pilot's Avatar
2004 E55
NO. You find the spot of the highest temp and thats where you put it. IT's not rocket science to figure it out
Old Jan 4, 2009 | 01:34 PM
  #44
Well....
It is the "World's quickest E500"
Joking aside...I was more impressed with my 2.0 60' on 19" street tires.
Old Jan 4, 2009 | 01:53 PM
  #45
jrcart's Avatar
"IT'S BEEN DONE FOR 50+ YEARS"....my point exactly!
No *****waiving here, just trying to help out and put some useful information out there. You keep using spray paint and I will have my tuners use the more current, exact and high tech method.
I bet lots of NASCAR, ALMS and DTM teams sit there with a rattle can while the car is on a lift and take the time to spray and wait to dry only to have far less than exact temps/results when they can use a $200.00 infared gun that will tell the the exact surface temp on any portion of the pipe down to the sixe of a pin head.
....you are an idiot if you think your method is better, or even equal!!!!!!!!
Old Jan 4, 2009 | 02:08 PM
  #46
E55Pilot's Avatar
2004 E55
It is EXACTLY Equal. You might want to spend some time actually building cars before you go waving your e-**** around
and writing a check is not building a car
Old Jan 4, 2009 | 02:42 PM
  #47
jrcart's Avatar
You are going to need a shovel if you want to dig yourself a hole any deeper my freind. I'm not really sure why you flew off the handle, I never said your method was incorrect, i just said there is a better and more exact method. Show me a top notch tuner or race team that uses your method...I can show you 20 that use the method I described. I really hope for your sake you are not a tuner becasue you are going to lose a lot of customers if you keep touting your "50+ year old tuning techology", i don't know about the other members, but I want a tuner that is going to use the most current and advanced tools available on the market to him...not a guy with a can of Krylon sitting under my car waiting for it to bubble and burn off
Old Jan 4, 2009 | 03:00 PM
  #48
E55Pilot's Avatar
2004 E55
Yes you did say it was incorrect. The pryo method is no better than the paint method which is actually better since you see where the resonance point is under load not free loaded like your method. Like I said when you start to build cars then let's talk 'cause your sure as **** not talking from experience.
Just because you bought a fast car doesn't mean that you know how to build it.
Old Jan 4, 2009 | 04:50 PM
  #49
Serenity Now's Avatar
03 E55 AMG
I randomly touch 10 spots along the exhaust with the tips of each finger. The finger that has the largest blister tells me where the x-pipe should go. Unfortunately if you have multiple cars you are installing an x-pipe on you may want the help of your wife, a friend, etc. Why waste money on a can of paint or an infrared gun
Old Feb 16, 2009 | 09:47 AM
  #50
storm's Avatar
Mercedes,Porsche etc
Smile
Actually the X-pipe should go MID PIPE, MID car where the resonators are, mercedes did that for a reason,, and the resonators have a sort of cross over x pipe internally, anyway..
the whole purpose is to even out the flow, and pressure,, and midway is the best place to do that..
