Headers - Kleemann vs. VRP - which one to get?
Old Jan 7, 2009 | 04:44 AM
jicl55's Avatar
2003 cl55 (sold)
Buying headers in about a week or so. I have a 2003 CL55 Powerchip, VRP pulley, Magnaflows, AFE filters, Rear Cat Delete..... can't afford VRP long tubes, that would be choice #1.... So, VRP shorties or Kleemann headers. I know with Kleemann, I would have to remove the primary cats (no cats.... ouch that's gonna be loud) and I'll either deal with it but I'll eventually have to put the rear cats back on. Whatever. From a pure performance/hp perspective, if you were gonna buy one or the other, which would you get? Any dyno sheets other than the ones from the vendors? Also, how much would an install on the Kleemann headers cost? I'm assuming I would need a reflash of the powerchip as well right? But even without it I should see some decent gains? Any input is appreciated.
Old Jan 7, 2009 | 06:07 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
If you go with Kleemann talk to Cory they have 200 cell cats that you can install. It's a easier install going with the VRP shorty headers but I'm old school and I remember that Derek ran the Kleemann Headers and he made some really good power with those so if I ever get the mod bug I will be using the Kleemann Headers. just my .55
Old Jan 7, 2009 | 06:41 AM
komp55's Avatar
ML550
Go with Evosports. VRPs aren't really headers at all, just somewhat enlarged logroll manifolds that offer gains only in the high RPM range. Kleemans are better headers than the VRPs, but you have hack up your very expensive stock catalyst system to install them. For me, the Evos seemed like the best compromise. Of course, YMMV.
Old Jan 7, 2009 | 09:03 AM
V12Godspeed's Avatar
Your worst nightmare...
If I were you I would wait and get VRP longtubes they are a work of art. Second choice would be Kleemann.
Old Jan 7, 2009 | 09:11 AM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Im kinda partial to KLEEMANN
Talk to Cory, find out were there is a Kleemann dealer in you area, they can usually install you headers and REPLACE YOUR CATS and have you car back to you the same day.
You might want to ask Cory about updating you ECU also
Old Jan 7, 2009 | 11:17 AM
jmf003's Avatar
'03 SL55
I'd actually suggest waiting a bit rather than buying right now.
Before the discussion went off into the weeds, there was some useful information being exchanged in this thread https://mbworld.org/forums/w211-amg/...what-look.html about developing long tubes that would replace the stock exhaust manifold and primary cats but would then bolt up to the stock exhaust.
If something along those lines happens, that might be the biggest bang-for-the-buck.
Back to your original question, I have the Evosport shorties and they've performed well for me. I paid over $3,000 for them but it looks like prices have dropped a bit and are now $2,490 for an E55.
I've also had good luck with VRP gear and their shorty setup costs quite a bit less at $1,499. Vadim at VRP says their shorties will perform as well as Evopsorts. Evosport disagrees. Who knows for certain?
Old Jan 7, 2009 | 11:47 AM
E55Pilot's Avatar
2004 E55
Get the EVOSport shorties. Skip the VRP "Shorties" as it's just a slightly larger log manifold. The EVOSport's are real shortie header.
Old Jan 7, 2009 | 01:05 PM
Vadim @ FD's Avatar
S600TT, R350
This discussion about headers has been going for a long time.
Here is a link to earlier thread:
https://mbworld.org/forums/w211-amg/...s-m113-v8.html
https://mbworld.org/forums/w211-amg/...m-m113-v8.html
In my experience supercharged cars are less sensitive to exhaust runner length than normally aspirated cars. With supercharger creating boost on the intake side, exhaust needs to be able to get the gases out as fast as possible.
Our Hiflow Exhaust Manifolds are the only shorties that have 1.75'' primaries, have a big 2.5'' collector that adds the volume that a typicall un-equal lentgh shorty can not create. Our collector flange is 2'' in diamater, again bigger than any other shorty on the market.
Prototype pictures:
Production Picture:
In the end the biggest judge is performance, many of board members went low to mid 11s with our headers on their cars, as part of our VR600 power packages.
Old Jan 7, 2009 | 01:22 PM
Vadim @ FD's Avatar
S600TT, R350
E55Pilot, I designed those when I was at evosport.
I know what they can do and I know that my new design can do.
Old Jan 7, 2009 | 01:29 PM
Vadim.... you just made me spit my coffee across the room..... hahahahaaa
Old Jan 7, 2009 | 01:31 PM
boohooramblers's Avatar
Not an AMG :(
+1
Old Jan 7, 2009 | 02:05 PM
phatmitzu's Avatar
2005 E55
Old Jan 7, 2009 | 03:17 PM
komp55's Avatar
ML550
This is where I get confused. Even if the header has a larger primaries and collector flange, doesn't it remain true that if you are bolting these up to the stock catalysts, you immediately have encountered a flow restriction since there is no increase in the size of the factory catalyst pipes? In other words, I don't understand the advantage of having a larger collector flange when it is immediately constricted back down to factory exhaust pipe size at the flange connections.
It seems like any of the shorties on the market offer better flow characteristics than the factory manifolds, but I would tend to think that so long as any of the shorties are bolted to the factory catalyst system, they all suffer for it performance-wise.
I wonder how much genuine interest there would be in an aftermarket front exhaust section set-up consisting of two single mandrel-bent pipes, each fitted with a high-flow metallic cat and before and after O2 bungs, that are direct bolt-in replacements for the stock front catalyst section of the exhaust system? Something like these would be a perfect complement to any of the various shorties header systems out there.
Old Jan 7, 2009 | 04:00 PM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
+1...
Old Jan 7, 2009 | 04:17 PM
URnext's Avatar
SL55 AMG
I would go with VRP shorties/hem's, cant beat the price and gives you similar performance gains as the other more expensive shorties.
If you did decide to go with Evosport shorties, then you might as well wait a little longer to get VRP long tubes. The price diffrence is not that big when comparing the return you will be getting in horsepowere gains.
FYI, the custom Long Tube Header Vadim made for my car bots right up to my stock muffler. If at any time should I want to bolt up my stock manifold, cats, etc to pass smog will be an easy task.
Old Jan 7, 2009 | 07:05 PM
TopGun32's Avatar
I think for the price and ease of installation..
VRP HEM
stage 1 cars don't need any more torque down low...
we need hp on top..
I'm saving up to buy a set soon and then have LET send me an updated ECU file.
probably mid of the year..
Old Jan 7, 2009 | 07:24 PM
phatmitzu's Avatar
2005 E55
VRP HEMs.
Like said, great price for the gain. The money you saved you can get yourself a pulley or tune(even both!).
Easy to install too. I did it myself in my own garage.
Old Jan 7, 2009 | 07:27 PM
Vadim @ FD's Avatar
S600TT, R350
I am working on H/X-pipe that will replace stock cats.
I will post more info next week.
Old Jan 7, 2009 | 07:35 PM
bobgodd's Avatar
2004 E55
You has teh PM.
Old Jan 7, 2009 | 07:40 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Priceless
Old Jan 7, 2009 | 07:44 PM
blueknight's Avatar
07 BMW X5
I love my VRP headers yes I noticed a difference in power as well, I just did an 11.86 @ Sac with only a pulley, stock Cont's and 20's in the front.
Old Jan 7, 2009 | 08:17 PM
What was your trap speed
Old Jan 7, 2009 | 08:41 PM
blueknight's Avatar
07 BMW X5
121.109mph
Old Jan 7, 2009 | 09:40 PM
bassn_07's Avatar
2006 E55 AMG
I also recommend VRP shorties. IMO I feel for the price and performance they would be the best choice, unless you wait to get long tube headers like many have recommended. I have VRP's VR600 package and my car is making some good power. My best trap to date in the 1/4 mile is 123.95 mph. I'm sure Evosport also makes a awesome product but at a higher price tag. Vadim is a class act and has great customer service. There has been several times I needed to talk to Vadim on the weekends and he has never failed to return my calls...that kind of service is hard to come by these days.
Old Jan 7, 2009 | 09:51 PM
bassn_07's Avatar
2006 E55 AMG
What's the expected cost and material used?
