Pulley for the M113 N/A V8 engine.
Old Jan 15, 2009 | 04:20 PM
Benz-O-Rama's Avatar
Guys,
Considering an under-drive pulley kit for my E500. I've spoken to evosport, and I know they have a $379.00 option.
I'm just not familiar enough with all of the MB tuners to make an educated decision. That's why I'm looking to you guys for vendors/prices/experiences.
Also, if I do go with a pulley kit, will I need to get a new ECU tune? I'm currently running one of Adam's famous Euro Elites Evotech tunes. With the so few ponies we're talking here, not even sure if it's worth it or necessary.
TIA.
Old Jan 15, 2009 | 04:26 PM
18T_BT's Avatar
CLK500
Originally Posted by Benz-O-Rama
Guys,
TIA.
never heard of tuning for under-drive pulleys...i'd personally not mess with 1-3hp gains by getting rid of the harmonic balancer that is in your crank pulley...this isn't a 4cyl where that doesn't really matter
Old Jan 15, 2009 | 04:29 PM
Not gonna touch the crank pulley or harmonic balancer. I'm talking about a pulley kit that under drives the accessories. Such as power steering, alternator, etc...
According to Evosport, this unleashes a massive 6-8 RWHP for my car.
Old Jan 15, 2009 | 04:36 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Nah, no new tune needed.
You are fine.
Old Jan 15, 2009 | 05:45 PM
Marcus Frost's Avatar
Real Cars
Benz-O-Rama,
I was recently talking to a W210 friend of mine about this whole crank pulley thing. I know with an N/A platform it's difficult to find places to make power without spending a ton of money - but for the sake of your car, I really would recommend thinking twice before touching your crank pulley, especially for a measily 6rwhp. We 55k guys don't really have a choice, not to mention we make a lot more power doing it, but I have NEVER EVER liked touching crank pulleys. There is WAY too much that depends on it and WAY too much at risk if for WHATEVER reason the aftermarket unit fails. I'm not saying that you will blow up your engine, but no matter what any tuner tells you, it does increase the risk significantly - and you gain very little for a lot of risk.
With the mods you have listed, I would definitely invest in a good set of headers. You will get more power (yes, I know they cost more) without any of the risks associated with the crank pulley.
Just my $.02 - avoid touching that crank pulley! In almost all cases, it's just not worth it!!!
-m
Old Jan 15, 2009 | 06:17 PM
Originally Posted by Marcus Frost
Benz-O-Rama,
-m
Ok, I think I'm confused. Someone please correct me.
I thought there are basically 2 types of pulley kits:
  1. Overdrive
  2. Underdrive
Overdrive pulleys are used on the crank to reduce rotating mass, and increase supercharger RPMs.
Underdrive pulleys are used on the accessories, not the crank, to effectively slow down the water pump, power steering pump and alternator which would relieve some of the parasitic hp loss caused by these devices.
I have no intention of touching the crank pulley or harmonic balancer. I want to change the pulleys on the accessories.
Am I completely confused?
And yep, headers are on the radar too.
Old Jan 15, 2009 | 06:21 PM
Real Cars
  1. Overdrive
  2. Underdrive
Benz,
Sorry I misread your original post. There's been a lot of talk of crank pullies these days.
Accessory pullies can also fail, and especially when talking about the water pump pulley if it does fail, it can lead to engine failure. This has and can happen. Even though I don't see accessory pullies to be as potentially problematic as an aftermarket crank pulley, I still see their benefit to be outweighed by the risks. Take the $400, stick in a savings fund, and put it towards headers. They really should be your next upgrade.
Good luck,
Marcus
Old Jan 16, 2009 | 12:51 AM
D.C. Designs's Avatar
Black Bimmer :)
hey clayton
finally some go fast mods
Old Jan 16, 2009 | 10:58 AM
Originally Posted by D.C. Designs
hey clayton
Well, let's not get carried away. I wouldn't say "go fast", I'd say "go not so slow" mods.
Old Jan 16, 2009 | 01:05 PM
Black Bimmer :)
put a blower on that bitoch and call it a day lmao
