Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Replace Brake Fluid
Step by step instructions for do-it-yourself repairs
Brake Fluid Flush
1 Post
W211,E90,E66,E39,E38,NSX,Z32-TT
Brake Fluid Flush
I'm getting ready to do a brake fluid flush. I looked through the garage and found a new can of ATE-Blue which is rated as Dot-4. The vehicle manual for the E55 states Dot-4+ required.
Am I going to be OK with this fluid? thanks.
Brake fluid change
Hey AZIPOD,
I dont usually reply, normally just look at all the threads, however I thought I would let you know that before you start any work on the brakes that you cant just do a normal break fluid change on this vehicle. To perform the procedure correctly the system has to be flushed using a STAR Diagnosis System.
Just thought Id throw in my penny worth of thought.
Hey AZIPOD,
1 Post
Thanks for the reply. I have access to the STAR Diagnostic system. However, I don't know if the ATE Blue (rated at DOT-4) is appropriate for the E55 (states DOT 4+ required).
2007 E63 w/P30 and Eurotech CF Diffuser
If you want to use something fancy, you can use Castrol SRF brake fluid. It will work with the ABS systems in MB. That is what AMG used in the cars at Laguna Seca. I specifically asked because I saw some ATE-SuperBlue in the garage. That was for the race car which had a completely different brake system. They recommended the Castrol SRF in the normal ABS system.
However, they also said that the Castrol SRF was much more hygroscopic that the standard brake fluid and should be changed twice as often. Given that Castrol SRF is $100/liter, that is a little crazy.
As for the SBC system, the viscosity is the key regardless of the DOT level.
http://www.ate-na.com/generator/www/...bf_sl6_us.html
When I installed my Brembo BBKs, I wanted to use this fluid, but because I don't have either the Star Diagnosis tool or a proper power brake bleeder in order to do a proper and complete brake bleed, I was not comfortable mixing this fluid with the Mercedes DOT 4+. So I ended up bleeding with new Mercedes brake fluid.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Does anyone know how to use a pressure bleeder to bleed the system. Or is star the only option.
If we can use the pressure bleeder I can do it myself for cheap.
If you're not looking to do a "complete" bleed where you activate valves within the SBC system, you can do a decent partial bleed using a Motive bleeder. Don't forget to bleed the calipers in the correct sequence (RRP, LRD, LFD, RFP). Note that since the SBC unit is mounted on the front passenger side of the engine compartment, the passenger front caliper is done last per the WIS.
Hmm I might just try a partial bleed.
Do you have to disconnect anything related to the sbc unit.
So I would connect the motive bleeder to the brake fluid reservoir pressure it up and start bleeding the capliers in the order you mentioned.
RRP = right rear passenger side caliper (one bleeder screw)
LRD = left rear driver side caliper (one bleeder screw)
LFD = left front driver side caliper (two bleeder screws)
RFP = right front passenger side caliper (two bleeder screws)
The attached file indicates the sequence by bleeder screw for the 8 piston front calipers, which have two bleeder screws. Note that this sequence applies when you're not using Star to activate the SBC unit (i.e., manual partial bleeding of brake system). When doing any work on the brakes, be sure to deactivate the SBC control unit first.
There are at least five methods that I know of.
1. Use STAR (preferred method if tool is available)
2. Use one of several aftermarket tools available to deactivate SBC
3. Use manual process described in WIS
4. Disconnect SBC connector at SBC unit (most common method)
5. Disconnect battery negative cable in trunk (maybe even safer than 4)
