Great deal on an OBD-II code reader!
Old Jan 26, 2009 | 11:23 PM
Donovan386's Avatar
E55
My CEL came on the other day so I looked around to see if I could get my own code reader for a decent price. I came across this one and couldn't pass it up. I printed out the page, took it down to Kragen and they matched the online price (same company). It reads codes and will clear them for you as well. For $23.90 + tax, you can't go wrong! It's a quality piece and easy to use. The display is a blue backlit screen that is very easy to read.
I believe Parts America is the same company as Kragen, Checker, Schucks, O'Reilly and a few others. They should all be able to do it for you.
http://www.partsamerica.com/ProductD...egoryCode=3389
Old Feb 9, 2009 | 02:24 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
thanks man. I bought it this morning. unfortunately, the thing wouldn't work on my 2005 C230 and I'm afraid that that will be the case with more later model MB's...
Old Feb 9, 2009 | 02:41 PM
Donovan386's Avatar
E55
Well that sucks. Worked perfect on my 03 E55. Did it just not work when you plugged it in or was the connector completely different?
Old Feb 9, 2009 | 02:55 PM
nlpamg's Avatar
it plugged in, but it said "searching..." then after a few minutes said "error"
Old Feb 9, 2009 | 03:00 PM
E55Pilot's Avatar
2004 E55
The OBD-II connector is a standardized part there are no alternate connectors
Old Feb 9, 2009 | 05:35 PM
Donovan386's Avatar
E55
Interesting- did you follow in the instructions in the manual? There's a certain order you have to do everything in if I recall correctly. Just trying to help- hope you get it figured out and it will in fact work.
Old Feb 9, 2009 | 05:42 PM
nlpamg's Avatar
yup, I turned on the ignition, but not with the engine on, plugged it in, it lit up and I pressed the button and it said "searching..." that's it.
Old Feb 12, 2009 | 02:54 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
http://www.alpha-bid.com/product68.html
Old Feb 12, 2009 | 07:57 PM
Wryfox's Avatar
2004 E55 AMG
price says $49.99. where was it $23.90?
