Changing oil 63's....
Old Jan 27, 2009 | 01:46 AM
jpohl402's Avatar
E55 then E63, now back to an E55
I change the oil myself on E55- drain two plugs, replace w new plugs..... what is the correct way to do on 6.2 NA motor?
Thx
Old Jan 27, 2009 | 06:42 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
Thx
What kind of oil were you using in your E55??
Old Jan 27, 2009 | 08:29 PM
jpohl402's Avatar
Typically Mobil 1
Heard they changed their formula and is more diluted now or something.
I think since then, twice Shell....
Old Jan 27, 2009 | 08:57 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
IIRC it's just one drain plug and the filter. I believe the dealers use extractor pumps through the dipstick.
Old Jan 28, 2009 | 02:07 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
In the E, the 6.2 has 2 drain plugs, but it is just not worth trying to remove the one on the small aluminum pan at the front. It must be glued in with loctite. The rear drain plug has a copper washer. I will replace it on my 3rd change. The dealer gave me the wrong one that last time so I re-used the old one. No big deal.
One thing though, 9qts is a LOT of oil. Make sure your drain pan is big enough.
Note, you can find pictures of the 63 engine with a large oil pan at the front of the engine, so I imagine they have different oil pan configurations based on the steering and structural member locations.
