Track fail. Still no 11s. Advice?
Old 02-02-2009, 09:52 AM
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
Went to a test&tune at Atco yesterday.
mods..
Evosport 175mm pulley set on Stock ECU
80mm TB
Evosport Phenolic Spacers
Code3 Heat Exchanger
CM30 Pump
K&N Filters
Removed secondary cats
my best run was a 12.1 @ 115.93 with a 1.88 60' and my best trap was on a 12.23 @117.06 run with a 2.0 60'. i was running on bridgestone re050 275/39/19 tires with about 23psi in them. i got a bunch of runs in and the constraint seemed to be traction, but even with that in mind the car is not trapping as high as i thought it would. when i first got it 4 months ago - it went 12.7@109 with the supercharger shutting off.
I know I should get better tires and rear wheels.
Only other thing I can think of is ECU tune - is that the only thing I am missing?
Old 02-02-2009, 10:06 AM
jmf003's Avatar
'03 SL55
Yep. You'll see a big improvement with a good ECU tune.
When launching on street tires, I get better results (~ 1.7 second 60') by inflating the tires to the recommended level. A lower 60' time won't improve your trap speed, of course, but would help your ET.
Good luck! You are just a whisker away!
Old 02-02-2009, 10:19 AM
prodigymb's Avatar
it was fairly chilly 45 degrees and the street tires just wouldnt hook at 35psi. only way i was able to get a sub 2.0 60' was to bring the pressure down.
i do realize that a 60' will not improve my trap speed - it was cold and the Re050s ar OK at best so I was not even expecting a 1.88. trap speeds were what disappointed me ....
Old 02-02-2009, 10:26 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Tune time brotha. Stock ECU is picking up too much boost and just pulling timing to compensate.
Old 02-02-2009, 10:29 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
+1...
Old 02-02-2009, 10:45 AM
blackbenzz's Avatar
haters crazy
Originally Posted by SaMaS
+1...
+2
Old 02-02-2009, 10:54 AM
prodigymb's Avatar
i have talked to wayne and jerry. sometime soon. i need to cut back on car spending. had this thing for 4 months and dumped 8gs into it ....
Old 02-02-2009, 11:00 AM
blackbenzz's Avatar
haters crazy
ECU tune is one of the cheaper mods though. Maybe we can set up another LET dyno tune day in the area and get you a custom tune. Much better than a remote tune
Old 02-02-2009, 11:02 AM
Jakpro1's Avatar
When you get to 35K, call me. Not that there's anyone I know that has spent that kinda cash on their car. That's would be friggin crazy.......wouldn't it?
HYEPWR's Avatar
2011 Black C63 Eurocharged V5
Id bet you trap much higher with the stock pulley. Proven many times-->pulley with no tune=less power. 115-117mph is a pretty avg trap for a stock car. Your 80mm TB and cat removal should be worth ~3mph or 118-120mph without the pulley.
Old 02-02-2009, 11:13 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
If you are concerned with spending,, then I would make sure I had 100% traction before trying to add more power.. 1.88 short time ,still sounds like some tire spin.. Based on your mods, I would think a 1.75 to 1.78 would be easilly attainable.. With a 1.75 sixty foot, you would have run a high 11.8 ET.. What was your race weight?
You can not go wrong witht he LET tune for adding big power and at a great price but still will need traction..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 02-02-2009, 11:17 AM
blackbenzz's Avatar
haters crazy
Jim has half that in rims and seats alone lol
Old 02-02-2009, 11:24 AM
prodigymb's Avatar
on the 1.88 it didnt seem to spin and i couldnt really replicate that launch, next best short itme was a 1.95. i need get a wheel/tire setup. i have 19" HREs and there is no 19" drag radials only 18 and 20.
as long as i run 19s i will be leaving some time on the table - but 19s is what i run on the street. i want to get my trap speed to where they should be as it appears that without a tune all my go-fast parts added NOTHING
Old 02-02-2009, 11:57 AM
jmf003's Avatar
'03 SL55
I still can't believe Jim cracked open his engine to try the SLR cams!
One more trip to the well for the ECU tune. The difference will be dramatic.
Old 02-02-2009, 12:09 PM
prodigymb's Avatar
yeah i guess it's not that i've been holding off on it......it's that i am waiting for wayne to make another trip out here so he tune my car in person (possibly on a dyno). i can't really have down time on my car right now to mail the ecu out there either.... so i'll just have to suck it up until he comes out here.
Old 02-02-2009, 12:14 PM
blackbenzz's Avatar
haters crazy
Ok then lets get some people together and set something up. I need a retune and a nitrous tune Wayne flew out here last time.
Old 02-02-2009, 12:19 PM
V12Godspeed's Avatar
Your worst nightmare...
Prodigy- when I met you at e-town you said no mods for your E...., I told you yeah right....the modding bug hasn't hit you yet!....I knew this was coming...lol!
Your story sounds a lot like my old E...I had every bolt on you could figure...until I put it all together with an ECU tune...had SLR cams, TB, ASP pulley, Klee Headers, Eisenman Exhaust, and a Big IC..
Without the tune best I could do was an 12.2 at 116-117...after the tune I ran 11.5 at 120+...
You need that tune!!!
Here is my old beast slipping all the way with some fat R888's...
http://www.youtube.com/watch?v=AgNFUdDMQHw
http://www.youtube.com/watch?v=LkW_Z...eature=related
Old 02-02-2009, 12:27 PM
Akademiks's Avatar
SL600
mods..
80mm TB
CM30 Pump
K&N Filters
Besides wheel spin I'm going to assume you let your car cool in between runs, right? Heat is a big factor as well... I take it your supercharger is in order with that new pump too right?
If coolings not a problem, the ECU tune should definitely set you straight. +1 to what everyone's been already saying.
Old 02-02-2009, 01:33 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
LOL, I stopped counting once I hit $50k and that was about 9 months ago I honestly don't even want to know at this point. $65-70k, possibly more, would be a very accurate guess at this point.
Old 02-02-2009, 01:46 PM
prodigymb's Avatar
ha i remember saying that
yeah little by little. weekend by weekend.....
8k is very cheap for all this stuff
-19" HRE 540R
-Eurotek CF Trunk Lip
-Eurorev CF Diffuser
-Lowered
-20% Tint / 5% on back window
-Tinted Mirror Turning Signals
-Debadged
-80MM AMG TB
-Evosport Stage I Pullies (175mm crank)
-Evosport Phenolic Spacers
-K&N Filters
-CM30 Pump
-Code 3 HE
-removed secondary cats and res
-Alpine W505 Screen with P1 Nav & Bluetooth
-Memphis Component Speakers front and back
-JL 500/1 Amp
-JL 10w7 Sub
-V1
i am up for it. going to call wayne and see if he has anything planned anytime soon
Old 02-02-2009, 03:31 PM
PLATINUM SPONSOR
2003 CL55
My car is heavier and 1.75 short times are average for my car using Nitto invos. I just need more power to get a better 60ft on these tires now. These are sticky street tires and you will not be at a daily driving disadvantage VS drag radials.. They have your size in`19`s. http://www.nittotire.com/#index%2Etire%2Einvo%2Esizes
Old 02-02-2009, 03:59 PM
prodigymb's Avatar
running 19" tires in general will yield to slower 60' time. there is less sidewall, and sidewall is stiffer. thats why radials and slicks have very soft sidewall
Old 02-02-2009, 04:07 PM
BlackOnBlackCLK's Avatar
2001 clk55 AMG
i recently talked to wayne from let he wants to do an east coast tune day he need a couple more people to make it happen give him a call im also in for a tune when they come out this way
I have vids of a few of your runs i can post them up if you want.
Old 02-02-2009, 04:16 PM
prodigymb's Avatar
can you email them to me -> mark.kogan1 at gmail dot com
that would be awesome
it was nice meeting you, congrats on the time too, you got that one early in the day !!! my 12.1 didn't come until some practice.
Old 02-02-2009, 05:43 PM
2001 clk55 AMG
I have your 12.4 and 12.1 runs i'll mail them to you. I think you need a tune & some sticky rubber...
Quick Reply: Track fail. Still no 11s. Advice?
