southwest (phoenix) LET custom dyno tune interest
If you are in the AZ area and would like to check out some quick soon to be quicker Mercedes feel free to stop by. Rich will be there about 8:00-8:30AM
Dyno-Comp is located at
8295 E. Raintree dr.
Scottsdale Arizona
85260
There is Extra parking around back.
BTW: Seriously, If you bring a pool of red bull for Wayne, you get an extra 10hp
Dynocomp
8295 E. Raintree Dr.
Scottsdale, AZ 85260
480-596-0500
http://www.dynocomp.com/
Dynocomp
480-596-0500
will be there! is there an order to this or how is this exactly going to work?
be soon to be quicker mercedes, are you referring to your car?
Oh...and the other Mike (hooley) brought some tasty donuts, which apparently Wayne is afraid of. LOL!
(btw, your car is going to be INSANE!). and a HUGE thanks to let for still making the trip after we didn't meet their minimum number of participants required for the group tuning session...sorry about that!the cars in attendance today seemed to put down some REALLY good baselines and there wasn't much room for improvement. kleemann put a damned good tune on my car and wayne did all he could to eak out 10 more hp and tq. although i hoped for more, i really didn't expect all too much knowing how well my car has been performing. what i really hoped for and wayne delivered on was the off throttle and part throttle maps. my car no longer stutters or bucks at low rpms at zero or minimal throttle. as a bonus, the downshifts are also much smoother. that in itself was worth the custom tune!!!
on a side note, we tested a renntech airbox. i didn't expect any real gains but it showed an additional 10rwhp/10rwtq gain on back to back runs vs my stock airbox. too bad those things are so expensive otherwise i would have ordered one on the spot!!!
thanks again to everyone!!!
Oddly, on my second baseline pull, it looks like my ECU was starting to pull about 6 degrees of timing due to heat. WTF? I've got the Code 3 7" heat exchanger, Johnson CM30 pump, the PTE 160 thermostat, and the -10C Star "mod"...I thought I didn't have to worry about cooling. I'll probably look at a split loop solution to further enhance my car's cooling capacity.
You maybe want to think about what kind of coolant you are running. Some Redline Watter Wetter wont hurt. Or being in Arizona a set up of running strait water this time of year may have some cooling benefits do to surface tension.
If all that fails maybe look into picking up a fan that flows more air over stock. .. some sort of duel compact fans.
Also a thing to remember is on most dynos the fans are not 120mph fans so it maybe slightly different on the street.
cant wait to see your results with the remote tuning. exciting stuff! i think that would aslo be my best option since its not too easy for me to get my car to a proper tuning shop. i guess remote tuning is the same as a custom dyno tune right?
I think the remote tuning is a great option, especially when you can do it for a custom tune and not a cookie cutter tune. In my opinion, this really is a competitive advantage since now the guys at LET can help you with a custom tune no matter where you are. Props to those guys for making themselves even more accessible.
I will talk to Rich about some solutions. If there is still some air in the system open up the coolant reservoir and then squeeze the radiator hose to see if you are getting any air bubbles to come out if you are then there is air in the system. Even with your cooling mods, part of me is wondering if its enough to keep up with you boost levels. i'm sure they guys over there can come up with a solution for you
what you need to do is data log on the street. i wouldn't be surprised if the problem is not with your system but with the poor airflow on the dyno. dynocomp is one of the best shops in town but they're definitely lacking in the fan department for their dyno. even my iat's got higher than they should have!
if you need to borrow my data logger just let me know.
