I know there's a lot of concern over failed airmatic components - are there any
With all 4 down you might not have a blown strut or air spring.
He also drilled holes through it and gave me a small rod to use for leverage. Obviously the rod won't go all the way through because of the air line but it is only torqued to 17.7 inch lbs. so it isn't very tight.
I checked the price on the MB tool and it was $25.35. The socket is much cheaper. I'm a tight wad because I never heard of a loose wad.
1. Push up on the front bottom of the bracket.
2. Pull on the top where the plastic comes to a point.
3. Lower the front and pull the tab from the slot at the back of the frame rail.
As for the custom socket my neighbor made. He said he used a angle grinder and a hand file to clean up the burrs. Most guys here could do it. Instead of drilling the hole you would only need to put two flat sides on opposite sides so that you could put a wrench on it to turn it. That is the design of the MB tool. (grinder again)
MB dealer gave a verbal estimate of $1250
$975.00 for strut
$220.00 for labor and possibly another $110.00 if they put it on diagnostic machine so lets just say $330.00 labor.
MB total $1305.00 + tax
My costs:
Arnott strut $675.88 including shipping minus $200.00 core = $475.88
Replacement plastic wire bracket from MB $3.25 + tax
my labor is free for me
My cost total $479.13
Savings = $825.87
spent last night removing failed driver side air shock. I have decided to replace the functioning passenger side as well. call me OCD but I feel better that both sides will be done.
The failed driver side came out easily since it was collapsed however the passenger side was a little trickier. I forgot to disconnect the battery until I was done so on that side I had to remove the 3 bolt upper ball joint and move it away some. I was able to get the strut out with that extra clearance.
I am using a floor jack on the lift point under the motor to get the car high enough to put jack stands under the points below the door hinges, so both sides are up.
10mm open end on the air line
Will post again after the install
You're lucky you have the 3 bolt removable top ball joint. Mine didn't have it and I had a tough time taking the ball joint apart.
Thanks for the help!
Arnott already has the order but note I could find NO forum discount AND the price has gone up about $125.00
Welcome to MB reliablity and ownership.
Oh well at least it wasn't the SBC brakes AGAIN
So much fun.
For the record on just MB E serices suspension. Bought new now at 121,000 miles
Replaced ball joints
Rear Airsprings
Rear airmatic shocks
Lf Front airmatic strut
Air suspension compressor
Not to mention 4 200 mile trips to the dealer for this service.
g.
But now lets compare suspension work to my diesel truck and Corvette also bought new
Diesel truck,, 168,000 miles
one wheel bearing
4 new shocks
Corvette 98,000 miles
1 set of shocks.
UMMM notice any comparisom.
The corvette has been race track tested at speeds way higher than the MB ever saw.
The truck has pulled loads and heavier weights than the MB ever had.
I just have so much fun working on suspensions in 98F heat and 100% humidity.
bought something way faster. I bought a plane and in 8 easy hours easily do 1200 road miles. Since the right has failed now I will have a complete new air suspension system in the last 30,000 miles so hopefully I can "just ride " a while.
Reluctantly I started this morning on the job. I had to make a new jack stand. I have 4 sets but dang me the one I wanted had 1 missing so I modified an existing one to do the jack pad work.
Having done one before I just started pulling the wheel then inner fender. I knew I would break the shock wiring since dumb thumbs broke the other sideon the 1st job. But age, practice stepped in I got this one out without breaking anything.
Then I loosened the bottom strut bolt, top bolts and left air line connected and wiring until I have the new strut from the shipper.
So basically in about 2 hrs I am ready to drop out the old strut. It was a bit of effort to pull apart the ball joint because mine is the one piece design.
I looked at arnott pricing again and the price has gone up a bit but what made it look like a lot more was they went from $100 core deposit to $200.
I think the shipped cost inc core deposit is about $640 or so. This nets out about $400 for the strut + shipping.
The last one I put on had a broken wire connetor on the top not nice. But I managed to make it work and not have to wait for another. Hopefully this one arrives in as good a shape as the one I send them exclusive of holding air.
When with Arnott and was VERY happy with both the quality of the product and the speed of shipping (they had one in Los Angeles so the shipping was closer). Sending the core back today for the $200 credit.
Hopefully, it will not be over 100 degrees and I wont have my garage blocked by a pile of decomposed granite the next time I have to work on this beast!
Haven't lowered the car yet because now I am pulling the front brakes off for new rotors / pads. The pads have 60,000 miles and just touched the wear sensor so they could run a while and the rotors have 122000 miles and are origional since new.
Nice to see now I have both front struts with lifetime warranty. Arnott discontinued our discount when I called. The strut was nice. The first one for the left side had the plug in at the top broken but I was able to use it. I wasn't impressed with the broken part. The 2nd one looked like new no defects. When the brake job is completed I'll know how it all pans out. Hopefully no error codes.
If the battery is disconnected expect a safety restrant warning in the FSS. It does clear after a few cycles.
Compressor is a new one from MB about 2 months ago
i'm a happy man.
I drove my E500 125000 miles(bought new) and during that time I had the front ball joints fail at 65,000 miles both airmatic shocks, rear air springs, and the compressor. Total expense for these parts amounted to right at $10,000 in dealer repairs.
Now you know why I no loinger own the car.
Remember forum members can save an additional 10%* off retail by using code MBSAVE12 during checkout
(Max $75 savings, not good on shipping, any core deposit or taxes if any).
