TPMS DIY install question
Old Feb 27, 2009 | 07:17 AM
DRTYLNDY's Avatar
So I need to replace my front TPMS sensors and I was curious if any here has done this themselves before? I bought the ones from tire rack and asked a local tire installer if they could do it but we were not sure what the long thin metal rod included was used for? Also does someone know what the torque specs are for the little bolt? Any ideas out there? Any help would be great, thanks!
Johan
Old Feb 27, 2009 | 09:42 AM
Jaybejay's Avatar
2004 E55 AMG--1999 E55 AMG--2007 ACURA MDX--E-GLIDE Electric Skateboard
What brand sensors did you buy from tirerack?
I need all 4 sensors, and can't find them on tire rack.
Anybody else know the brand from tirerack?
Old Feb 27, 2009 | 11:47 AM
bobgodd's Avatar
2004 E55
You can order the sensors from www.buymbparts.com.
TPMS Sensor - 315Mhz
To the OP, I would say just crack open the tire and look at the old one and make the new one look identical to it
Old Feb 27, 2009 | 02:54 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
Johan
torque is written upon the sensor (in NM)
the thin rod is only to counterhold the valve while tightening (after inserting the rod inside a similar hole the valve itself has)
.. in other words, it serves nothing
