I love my recently acquired 05 e55, but need help understanding the following:
1) Had my local 'stealer' print options on my vin. Does anyone know what some of these are:
910 DYNAMO WITH HIGHER CAPACITY (FFO)
28N STEUERCODE WERK SINDELFINGEN/GRAZ
805 Y OM 14/1/M/X
810 CD CHANGER (btw I cant find this?)
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
2) Armrest/console: I have the roller thing (you roll the top back to open) and inside there is no cupholder insert. Does anyone know what the part # is for that? The dealership gave me 66920118 but when I search that part online it doesnt look right.
3) To enable bluetooth should I just be able to plug in the Merc BT adaptor to the black thing in the rear of the console? Or do I have to also buy a puck?
4) If you had a limited budget, would mods would you recommend as must haves for <$1K?
805 Y OM 14/1/M/X
the cd changer is in your dash under the comand unit... right where the hazard triangle is, there should be a small chrome button, hit that the the unit should pop out....
as for bluetooth, if your car has the mhi kit, then all you need is the puck... in your arm rest console, do you see the adaptor where a phone would normall sit?
Good luck finding a mod for under $1k..
On second thought, you could look into replacing the intercooler pump, and if you can do the work yourself, you can also afford to buy a bigger heat exchanger for under $1k.
Yes I see a black adaptor (not a cradle) that must be the MHI?Originally Posted by harjothundal
the cd changer is in your dash under the comand unit... right where the hazard triangle is, there should be a small chrome button, hit that the the unit should pop out....as for bluetooth, if your car has the mhi kit, then all you need is the puck... in your arm rest console, do you see the adaptor where a phone would normall sit?
Yes the Johnson pump is on my list, hadn't looked into the heat exchanger yet...what are the benefits?Originally Posted by bobgodd
Good luck finding a mod for under $1k..On second thought, you could look into replacing the intercooler pump, and if you can do the work yourself, you can also afford to buy a bigger heat exchanger for under $1k.
PS This forum rocks! Thanks for your help guys
Quote:
That's a high output alternator
Awesome, thats one mystery solved. Thanks E55Pilot!
805 Y OM 14/1/M/X
I have an extra cupholder if you need it. PM me. Actually, I have a bluetooth puck also.Originally Posted by benjamin4000
I love my recently acquired 05 e55, but need help understanding the following:1) Had my local 'stealer' print options on my vin. Does anyone know what some of these are:
805 Y OM 14/1/M/X
Nick
my cupholder broke, and im leaving it broken so girls wont bring their drinks in my car anymore. "do you have a cupholder?" "hell no *****" lol
Explore
