School me on A/F Ratios Please
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Can someone school me on af ratios please.
Like what stock e55 ratios should be and what af ratios should be after ecu etc etc etc
Wikipedia is my friend. This is how I learned what it was....
http://en.wikipedia.org/wiki/Air-fuel_ratio
Air-fuel ratio (AFR) is the mass ratio of air to fuel present during combustion. When all the fuel is combined with all the free oxygen, typically within a vehicle's combustion chamber, the mixture is chemically balanced and this AFR is called the stoichiometric mixture (often abbreviated to stoich). AFR is an important measure for anti-pollution and performance tuning reasons. Lambda (λ) is an alternative way to represent AFR.
In industrial fired heaters, power plant steam generators, and large gas-fired turbines, the more common term is percent excess combustion air. For example, excess combustion air of 15 percent means that 15 percent more than the required stoichiometric air is being used.
A mixture is the working point that modern engine management systems employing fuel injection attempt to achieve in light load cruise situations. For gasoline fuel, the stoichiometric air/fuel mixture is approximately 14.7 times the mass of air to fuel. Any mixture less than 14.7 to 1 is considered to be a rich mixture, any more than 14.7 to 1 is a lean mixture - given perfect (ideal) "test" fuel (gasoline consisting of solely n-heptane and iso-octane). In reality, most fuels consist of a combination of heptane, octane, a handful of other alkanes, plus additives including detergents, and possibly oxygenators such as MTBE (methyl tert-butyl ether) or ethanol/methanol. These compounds all alter the stoichiometric ratio, with most of the additives pushing the ratio downward (oxygenators bring extra oxygen to the combustion event in liquid form that is released at time of combustions; for MTBE-laden fuel, a stoichiometric ratio can be as low as 14.1:1). Vehicles using an oxygen sensor(s) or other feedback-loop to control fuel to air ratios (usually by controlling fuel volume) will usually compensate automatically for this change in the fuel's stoichiometric rate by measuring the exhaust gas composition, while vehicles without such controls (such as most motorcycles until recently , and cars predating the mid-1980s) may have difficulties running certain boutique blends of fuels (esp. winter fuels used in some areas) and may need to be rejetted (or otherwise have the fueling ratios altered) to compensate for special boutique fuel mixes. Vehicles using oxygen sensors enable the air-fuel ratio to be monitored by means of an air fuel ratio meter.
Lean mixtures produce hotter combustion gases than does a stoichiometric mixture, so much so that pistons can melt as a result. Rich mixtures produces cooler combustion gases than does a stoichiometric mixture, primarily due to the excessive amount of carbon which oxidises to form carbon monoxide, rather than carbon dioxide. The chemical reaction oxidizing carbon to form carbon monoxide releases significantly less heat than the similar reaction to form carbon dioxide. (Carbon monoxide retains significant potential chemical energy. It is itself a fuel whereas carbon dioxide is not.) Lean mixtures, when consumed in an internal combustion engine, produce less power than does the stoichiometric mixture. Similarly, rich mixtures return poorer fuel efficiency than the stoichiometric mixture. (The mixture for the best fuel efficiency is slightly different from the stoichiometric mixture.)
Another one...![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
http://www.bristoldyno.com/tech/airfuel.htm
In addition to the ignition timing, the other aspect of vehicle tuning that is most commonly addressed is the fuel delivery. The amount of fuel being sent into the combustion chambers is commonly measured as an "air / fuel ratio" which is just like it sounds - a number representing the ratio of the amount of air to the amount of fuel being burned in the engine. An internal combustion engine mixes fuel with oxygen in the air and then ignites that mixture with a spark plug. From a strictly scientific point of view, the optimum mixture of air and common gasoline is around 14.6 parts of air to every one part of fuel for an air/fuel ratio of 14.6:1. At this ratio and under the right conditions, all of the gasoline and all of the oxygen can burn leaving nothing except for the combustion products. This is called the "stochiometric" ratio. It is just like the ratio of 2:1 for hydrogen and oxygen, as when they react (or burn) in that ratio and under the right conditions, everything is used up and only water (or H2O) is left. Fortunately for us, the oxygen in the air is never completely used up when gasoline is burned. The main reason for this is the fact that air is only 20% oxygen, and the remaining 80% is comprised of things that will interfere with a perfect reaction. If one were to mix gasoline with pure oxygen, the stochiometric ratio would be approximately 3:1 and the reaction would be entirely more dramatic with a much greater chance of a "complete burn."
Higher ratios, or mixtures that contain more air than what is desired are considered "lean." Lower ratios, or mixtures that contain more gasoline that what is desired are considered "rich." The two terms are used much like "retarded" and "advanced" when describing ignition timing. Historically, the terms were used to describe deviations from stochiometric, much like "retarded" and "advanced" were used to describe deviations from TDC, but they can also be used to describe deviations from the desired point and changes to the current state. "Leaning" the mixture means adding air (or reducing fuel) and "richening" the mixture means adding fuel (or reducing air.)
Since there is always some oxygen left in the exhaust gas stream of a running engine, we have an easy way of measuring the air/fuel ratio. An "oxygen sensor" can be used to measure the percentage of oxygen left in the gas stream, and a computer or other electronic device can be used to back-calculate the air/fuel ratio that will result in that particular oxygen percentage. "Narrow-band" oxygen sensors respond with a voltage output that is sent to the computer that is between 0 and 1 volt. "Wide-band" oxygen sensors send a 0 to 5 volt signal which allows for a much higher resolution and are therefore much better for tuning. "Lambda" is a commonly used term that is used in place of the air/fuel ratio number, as many devices use or report lambda values. A lambda of 1.0 is equal to the stochiometric ratio (14.6:1 for air/gasoline) and is adjusted accordingly - a lambda of 0.82 is equal to 12:1 air/fuel ratio.
The "best" air/fuel ratio for a particular vehicle is a matter of great debate and I will do my best to avoid that debate in this article. Simply put, there are a number of factors that one must consider in determining the best ratio, including power, safety, and fuel economy. Fuel economy is the easiest to understand, as a lower air/fuel ratio means more fuel and obviously lower fuel economy. As far as safety is concerned, richer is considered safer (to a point) as the extra fuel helps things run cooler. The lower temperatures help reduce the chance of autoignition and can literally keep engine components from melting. The safest air/fuel ratios are continuously being debated, but it is widely accepted that 13:1 is a good ratio for normally aspirated engines and 12:1 is good for forced induction engines. Many choose to go even richer, even 11.5:1. Autoignition (or "detonation" or "knocking") is considered a critical concern with rotary engines, and many tuners choose to go even richer than that. One must also keep in mind that these "safe" ratios are considered safe because they have been tried with many thousands of vehicles over many years by dyno operators that use the same equipment that most people are likely to encounter. Therefore, a safety margin that takes into account the accuracy of that equipment is inherently factored in. If it were common for turbocharged cars to blow up at 12:1 as measured on commonly used equipment, then the "safe" air/fuel ratio would have been lowered.
As far as power is concerned, I'll say only this: Every vehicle is different. If one wants to find the best air/fuel ratio for generating power, one should put the vehicle on a dyno and test it. Many believe that a particular ratio will result in the most power under any circumstances, and that belief is just too narrow-minded. There are far too many factors involved to make such blanket statements.
Regardless of the actual ideal air/fuel ratio number, almost everyone wishes to see a nice, flat air/fuel graph. This means that the ratio stays constant throughout the rpm range. A perfectly flat air/fuel graph is certainly not necessary for optimum engine performance or safety, but it is a nice thing to show off when tuning a vehicle. The smoother the air/fuel curve, the better the drivability will be and the smoother the power output will be. All good tuners realize that a little variation with the graph is perfectly acceptable, especially when one considers the factors involved. One must consider the accuracy of the oxygen sensor, where it is placed in the exhaust stream, the velocity of the exhaust stream at different points in the rpm band, the tools that the tuner has at his disposal to make changes, etc. Another important factor is that most air/fuel ratios are measured via a tailpipe sniffer. This method has proven to be an excellent way of measuring the ratio, but it is not perfect at low rpm. At low rpm, an engine may not be producing enough gas to displace all of the atmospheric air in the tailpipe, and this will produce a false lean reading because of the extra oxygen - as one can see in this chart. This phenomenon is going to be more pronounced in small-bore engines with large diameter exhaust piping. Two important things must be considered when one is tuning with a tailpipe sniffer because of this phenomenon. One, a flat line across the entire rpm band will mean that the actual air/fuel ratio is too rich at low rpm. Two, a real-world driver is almost never at wide-open-throttle at such a low rpm, so the air/fuel curve at that point is something that the driver will never see. One can also see from the chart that the catalytic converter has no significant effect on the air/fuel ratio in this particular vehicle.
The flatness of the air/fuel graph when one is done tuning is mainly going to depend not on the competency of the tuner but on the type of fuel management system being used and its resolution, and the patience of the customer and/or his willingness to pay for dyno time. One must also ask - is a perfectly flat air/fuel curve best? Many assume that a flat line at 12:1 or 13:1 "across the board" is best, but why is that? How could it be possible that the exact same air/fuel ratio be optimum for every rpm and load? This idea has been largely ignored in automotive enthusiast circles, as "good" tuners with adequate engine management equipment produce air/fuel curves that are flat "across the board" at the desired ratio. Thankfully, this notion has been challenged recently, and experienced racers and tuners have begun to realize that air/fuel curves should not necessarily be flat. Turbos can spool up faster if the ratio is a little lean during that time, and rich ratios are more needed in the higher rpm range where more heat is being produced. Keep in mind that wideband oxygen sensors have only been in widespread use since the late '90's, and chassis dyno testing has only become truly popular in recent years. All of us are still learning. Few people have been able to perform true scientific experiments, and therefore few people truly have the knowledge to make blanket statements concerning what is best for a particular vehicle or group of vehicles.
When performing dyno testing and tuning, one must ask oneself "what am I trying to achieve?" If maximum power is the goal, then just look at the power curve first and make adjustments accordingly. The fuel curve is only used as an aid. Many NA race car owners tune in this manner, and by the time they are done the air/fuel ratio is sometimes between 14:1 and 15:1. This is usually not considered "safe" by anyone, but most race car teams accept the fact that they usually change the engine at least once during a typical season. Most street car owners are willing to sacrifice the 3 - 5 hp that they might get by running so lean and instead opt for an air/fuel ratio that will help their engine last for many years.
In a few words air fuel ratio is for "Thermal Management". There seems to be a lot of confusion and hear say about afr and power output. I have heard people saying that car xyz is running too rich and it's losing a lot of hp. A richer air fuel mixture wont cause your engine to lose as much power as some like to think.
It's ignition timing that creates HP guys. Not Air fuel ratios... Maintaining a safe afr is to ensure the engine stays together.
The ideal afr is 14.7:1 that is called stoichiometric. You want to be at or near stoich for good gas mileage and clean burn during NORMAL driving conditions. At WOT the car regardless if its NA, SC, or Turbo will want to run richer. NA being leanest and Turbo wanting to run richest.
FI cars run richer because the added fuel cools down the cylinder temps.
NA cars can run a lot leaner.
Hope this helps.
Hope this helps.
Back in the 90's Kennebell, B&M, and Vortech released some really cool dyno charts as to the difference in HP vs A/F ratio.
What they found was you loose 2% power for every 0.5 AF richer below a 12:1 A/F ratio. Now on the flip side, yes they ran one LEAN
, they only gained 1% total HP above the 14.7:1. Their bottom line was, run your FI motor at or BELOW 12:1 as was stated above, it runs COOLER, LESS chance for detonation, and you can run MORE total timimg ,wihich gives you WAY more total HP then a Leaner mixture does. Also, they did melt one down trying to get it to run at 16:1.
I know I have the charts somewhere in my house, I'll try to scan them this weekend. They did charts on static compression vs Boost, total timimg vs HP, AF ratio verse HP, etc, etc.
Again, their BEST attempts were with a AF at 12:1, and total timing at 35 degrees, for ALL of their tests engines.
I used this info while road racing my 91 stang with a whipple, and NEVER had ANY engine failures, can't say the same about my trannies
I would set my AF at or BELOW 12:1. Heck I even melted one rear valance because I was SO rich I would throw flames out of my exhaust system. Received a black flag at Nelson Ledges for this, as my car was on fire, opps.
Oh well, I will look this weekend guys for the info.
See yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
PS: GRAET info above guys!
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
See yeah
Books have been written on this subject as it plays into the overall theory on combustion engines. Some good info has been posted I just wanted to add something:
Shooting for a particular AFR is a bit of a misnomer. The truth is that every car has it's challenges - whether it be the environment in runs in, or the particular modifications it has. You need to think "big picture" when talking about AFRs, not just that you need to hit a particular number.
Good example - a friend of mine was working on his car and found that he was able to cure some inefficiencies with the stock turbo setup and wound up getting boost to exceed the reading ability of the stock map sensor. Since he can't replace the sensor and reprogram the ECU with a new scale, anything above the MAP sensors reading is essentially not visible to the ECU. In his case, as full MAP reading, he has to run a bit richer than usual to compensate for the fact that when his MAP sensor is seeing it's max of 20psi and delivering fuel for 20psi, he needs to be program in the ECU itself a bit of breathing room with fuel to allow for a few more psi over the MAP sensors max reading.
There are a lot of situations like this, even with 55s. It's really an art getting an engine to run properly and AFR plays a good role in that. I think trying to learn about it in a thread like this is really just a very brief start, you need to spend some time reading about it more in depth and the challenges that present themselves when tuning to get a good feel for it before you even attempt to start doing it yourself!
-m
-m
See yeah
I will, though, disagree about 35* max being perfect. many modern cars and modern combustion chambers have an optimum timing advance that gives the most power. This number can vary--depending on the engine in question. More timing will always give more power ---to a certain point----Ill guess somewhere between 25*-35* advance.
The best way to tune a FI street car is to fill it with 91 octane(if u usually use 93)---tune it to 11.7 AFR and as much advance as you can get until you get detonation---then dial the timing back 2 degrees. this is very safe tune.
That said---In modern ECU controlled cars ---the max timing advance is only under perfect circumstances. Unless the safety measures are totally removed--in general The ECU will advance timing to the max...then if it hears detonation...or air temps are too high or the tranny senses too much torque...or who knows what else...timing will be pulled back.
