Hows the E63 with Performance Package Ride
Old Mar 18, 2009 | 11:00 PM
KV3BLUE's Avatar
2008 E63, White/Black, P030
Hi guys. I am in the process of purchasing the 2008 E63 and was wondering hows the ride quality for the E63 with the performance package? I am hoping its not a bone jarring ride, because I live in Southern CA and the roads are pretty bad around here. Thanks.
Old Mar 18, 2009 | 11:24 PM
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
Smile
It's adaptive, I have never ridden in one w/o it, but I am pretty sure w/ the settings on comfort, the 2 cars are the same. I think its great, I wouldn't get one w/o it! Get DISTRONIC!!! its your friend.
Old Mar 18, 2009 | 11:35 PM
jangy's Avatar
2015 S212
No E class has a bone jarring ride. Get the 030 pack for sure. It is a sweet OEM setup.
Old Mar 19, 2009 | 12:40 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
I love the performance package suspension on my E63. However, it does indeed provide for a "harsher" ride than the regular E63, as I've driven both more than enough. The P30 package suspension is definitely stiffer, and was calibrated more towards track use. That being said, once you're used to it, you'll never want to go back to a non performance package AMG ever again
Old Mar 19, 2009 | 02:36 AM
rarfinancial's Avatar
CLS63
So anyone know what is different? is it the shocks? or the air bags or both? I am looking into some how getting a set of coilover to fit.. or beaf up the shocks or sway bars..
Old Mar 19, 2009 | 10:13 AM
KV3BLUE's Avatar
Wow. I usually don't soft rides anyway. I'll post an update when I purchase the E63. Thanks guys!!
Old Mar 19, 2009 | 10:43 AM
UT_AMG's Avatar
08 SL55, 07 E63, 07 S550
Mo, Rich I'm quite fed up with your E63 with the P30 package. Im going to trade and get me one with P30. Thanks a lot guys.
Old Mar 19, 2009 | 12:23 PM
jangy's Avatar
2015 S212
Out of curiosity, I would love to measure or check the Sway bars. The E55 already has some pretty fat ones but another 5mm may help some with the initial lean.
The 030 package has different "tuning" for the Airmatic. I am not sure what the difference in parts is, though.
The LSD you have. The ECU tune you have.
Old Mar 19, 2009 | 02:00 PM
I know its 50% stiffer and a different wheel carrier made of cast-iron. I know the shocks are different, I don't know the differences. We have 14mm bolts on everything on the suspension, as opposed to 12mm... I want to know the weight difference in the rims.
http://www.703power.com/benz.php
Old Mar 19, 2009 | 06:44 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Jon,
For the Performance Package E 63 AMG (P30)
The front axle 35% stiffer in rebound and 35% - 45% stiffer in compression.
The rear axle, the suspension is 45% - 60% stiffer in the rebound and compression.
Warmest regards,
AMG Private Lounge Team
I also just posted this on the PL. And I agree with MB_Forever on the ride. Slightly "harsher".
The higher spring rates do change the character a bit from a standard E. The main benefit right now is primarily the unique status.
The only time I was able to really evaluate the difference was in Vegas at an AMG PL event where I could compare head to head. The P30 was more "planted" and held a line better resulting in smoother steering inputs. The LSD helped only on 1 or 2 corners, mainly the one going over a bump onto the front straight. I will also say that the pro driver I was following did not have the P30 and would have had no problem pulling away.
I think we also found that the wheels on the P30 are heavier by a pound or two from the stock rims, although the rear rim is 0.5" wider.
Old Mar 22, 2009 | 04:05 AM
So our rears are 10"??? or ?
What's the advantage of them if they are heavier?
Old Mar 22, 2009 | 12:29 PM
CLS63
O.K lets see if anyone can post Part #'s for shocks and or air bags, springs for the CLS63 vs CLS63 030. Jang what's up man come by and say hello... You gotta see some of the new toys
Old Mar 22, 2009 | 05:05 PM
P30 rears are 9.5" vs 9" for non-P30 cars.
The advantage of them is that they are a unique identifier of a P30 car.
I also like the look better than the normal rims.
Old Mar 24, 2009 | 06:48 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
What is a P-30 car? You mean there are TWO suspensions available for the E63 ?
Old Mar 24, 2009 | 07:07 PM
MB_Forever's Avatar
There is an optional performance package that can be ordered on the E63 designated with the alpha numeric code P30. The P30 performance package comes with different wheels, stiffer suspension (mainly programming but there maybe hardware changes as well), ECU delimited to 186 mph instead of your standard 155 mph, alacantra steering wheel, AMG limited slip differential. So yes, there are two different suspension setups available for the E63. This was also available on for E55s, but for the European models only NOT U.S. cars.
Old Mar 24, 2009 | 08:10 PM
LB63's Avatar
E63, S550
I love my p30 package, only change would be for the comfort setting to be softer (it's actually the wife's request )
