Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class AMG: How to Change Your Oil
Step by step instructions for do-it-yourself repairs
DIY E55 oil change?
CLS55 AMG 030
DIY E55 oil change?
anyone know where there is one? i cant find it with the search thread i found the one for a E63 but not for E55 what parts are needed? thank you
Bone up on using the search feature. Here's one of several threads on the topic:
https://mbworld.org/forums/w211-amg/...need-help.html
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Parts required
8.5q 0w40
Oil filter
2 drain plug bolts and washers (mb doesnot recommend using old ones)
Oil pan has 2 drain plugs one on the rear of oil pan holds majority of oil and one by the front sway bar holds 1/2 quart.
You can measure amount of oil via instrument cluster or you can buy dip stick tool to see amount of oil in the car.
8.5q 0w40
Oil filter
CLS55 AMG 030
ok Thanks I only bought 8 but i will go buy 2 more for back up to keep in the car like my dad does in his F430, for some reason that thing drinks oil.
