CLK BS 15" rotor
. Did you just replace the rotor and keep the hat?psk....it relates in no way. EVOSport rotors are the bomb compared to those 20lb rotors pictured.
Are you using BS hubs and spindles?
What have you put on the rear?
Do you still have the 3.5L motor in the car?
I do agree that some after market rotors (including the EVOsport ones) will wear out faster but that is something you give up with the weight gain. For me, unsprung weight is huge.
These will not work with an E class becuase the hub backspacing is different. It's basicly an upgrade for the clk bs.
Yes this car started off as a clk350. No the clk 350 motor is not in the car anymore. I'm working on some transmission stuff with the new motor. I'll post up about it later.
, has zero experience and or knowledge regarding mass resisting acceleration (inertia) based on its location with respect to the axis of rotation and has never heard the term offset pistons to maximize surface area.
Oh yeah, and HOOSIERS nonetheless ?!?!?!?! Yikes man...please give us some driving impressions. Very tastefully done and congrats!!
Thanks man. I am actually doing this as a senior project for my engineering degree, so yea. I just posted this because i thought it was kinda cool. Anyways the actual rotor is a brembo 15" and the hat i cnc'd at my buddy's shop. I basicly copied the black series hat and enlarged the outer part to fit the rotor. I did some research on a ceramic rotor and a lot of people who have put a ceramic rotor on a car that didn't come with it oem had a lot of issues with the brake booster and the abs system. Why I'm not sure but that was the general input from the "brake experts".
The hoosiers are awesome. Fortunately they have a pretty good fitment for the black series with an upgraded wheel. It makes the car handle a lot sharper for lack of a better word. I'm going to buttonwillow sometime soon and i want to do some suspension tuning and see how she does.
thx
Jim the Hoosiers work great. I almost got the corsas but I wanted something a little wider in the rear for better cornering and also to hold the power down. They wear much faster then the corsa that's for sure but I feel I can predict the car much better with the Hoosiers. With the 265/35-19 in the front being a tad taller then stock can allow for the actual suspension being a little more even rather then keeping the ride height a little higher in the front. It feels better when braking through turns. I hope I gave good input.
And when did I ever claim that money could buy intelligence??? Hell, I learned everything I know from the internet, just like you !!
