No Throttle Response, ESP/BAS on after battery disconnect...
I drove home and disconnected the battery to reset everything and when I hooked it back up only to have no throttle pedal response whatsoever. Additionally, even after I turned the steering wheel left and right lock to lock I still had ESP/BAS failures. I disconnected and reconnected the battery a few more times over the following hours, and one time I got throttle response back so I drove into my garage while I had the chance. I then turned my wheel left and right and my ABS and BAS failures cleared, as they should.
If I turn the car off and then start it back I get a Check Engine light for P0120 - Throttle Sensor/Pedal Position Circuit A. I figured it was the infamous throttle pedal failure so I went out and bought one from the stealership today, unhooked the battery, installed it, reconnected and guess what.... no throttle pedal response and ESP/BAS won't clear again.
I have tried to leave the key in the on position before starting for 5 minutes or so hoping the throttle body would adapt, but no look. Anyone know what's going on here?
Not sure if you are stock, but if stock, maybe a trip to the stealer to see if they could reflash the ECU for ya.
Hope you don't have to buy a new one......bout 2K give or take
Seriously, I need to have Ken check mine out. I can show you video of how mine did the same darn thing as yours. Only thing with mine, is that with other ECU's, it did not...just the bricked one.
Go figure.
Glad the beast will be back.
You know, what gets me is that this is Mercedes, the people that made the car and all you seem to get anymore is "parts changers" instead of actual technicians that know what they're doing. Hell, I can change parts until I happen to luck across the culprit myself. In fact, I never take a car to the dealer unless it is absolutely, positively a last resort because I know I do better quality work myself because I wrote the check for the car. That's why it always makes me laugh when someone replies "should have taken it to the dealer" ... why, so they could change parts until they got which one was defective and then have some ridiculous claim that all of them failed at once or that one shorted out, killing the others so it could be on my dime in the end.
It seems to me $100K+ is enough money to have implemented a car of enough intelligence to tell the dealership which electrical component of the car has failed, but what do I know. I think there is more intelligence on this forum than in all the dealership service departments in the U.S. combined, but maybe I'm just 0 for 2 on Merc service departments.
////end rant and breathe
Did the ESP computer fix the problem?
I'm going to try a new throttle body (actuator) and reset via star.
Thanks.
fixed "No-Function, No start, No park unlock, problem, it was circuit 15 (K12 relay), it ran ! Yea!
the auto elec now could assess it, but 2 weeeks later he had limited time for tricky probs & on driving around he also was mystified how it can at times drive fine, then randomly if the revs are below 1000-RPM & traveling above 10KPH The BAS lite comes on & No throttle function, can back gear to 2nd to spin motor up, ignition off & on >power back on !!
I was given car back to play with till he had more time, I removed (progressively) all relays, stripped down & cleaned & restored All relays with high hopes as several were in poor condition, result >Same
If we approach intersections in 2nd gear left foot braking & right foot keeping motor above idle it is OK, not easy & unsaleable.
Surely Someone has some tips ??
Cheers
Cheers
Thanks,
