Car got towed into MB San Diego today
Old Apr 6, 2009 | 06:56 PM
jicl55's Avatar
2003 cl55 (sold)
Unhappy Car got towed into MB San Diego today
Driving down 163. Got off freeway at Friars and got to stop light..... smoke was coming from engine thru vents. Immediately pulled over at Fashion Valley behind the Firestone right there and opened the hood to let it cool (I thought worst case scenario, Firestone should have a fire extinguisher...) and got my whip towed to MBSD. Looks like fluid was leaking and was going onto pulley and that is where is was smoking..... whatcha think? Not sure if it was oil.... transmission fluid or what.... probably find out tomorrow
Attached Thumbnails Car got towed into MB San Diego today-dsc00181.jpg   Car got towed into MB San Diego today-dsc00182.jpg   Car got towed into MB San Diego today-dsc00183.jpg   Car got towed into MB San Diego today-dsc00184.jpg   Car got towed into MB San Diego today-dsc00185.jpg
Old Apr 6, 2009 | 06:58 PM
jicl55's Avatar
2003 cl55 (sold)
more pics... sorry took them w/ camera phone
Attached Thumbnails Car got towed into MB San Diego today-dsc00187.jpg   Car got towed into MB San Diego today-dsc00188.jpg   Car got towed into MB San Diego today-dsc00189.jpg   Car got towed into MB San Diego today-dsc00190.jpg
Old Apr 6, 2009 | 07:55 PM
bobgodd's Avatar
2004 E55
That sucks. Hopefully they can take care of you without the rapeage.
Old Apr 6, 2009 | 08:08 PM
Max.H's Avatar
E55
Do you see a leak at the bottom of the car? If it's red that should be tranny fluid. I'm guessing it's more like engine oil. Maybe bad valve cover gasket? Keep us updated. Hope it works out.
Old Apr 6, 2009 | 08:23 PM
ECBAOBAO's Avatar
nascar
+1
I think most likely engine oil too, hopefully nothing too major!
What color was the smoke?
Old Apr 6, 2009 | 08:28 PM
jicl55's Avatar
2003 cl55 (sold)
Yeah, bought extended warranty through mbsd last time i got "rapeage" (3500 outta pocket for ABC pump installed and that top pulley that is covered with oil went bad..... the bearings got fried.... forgot, like $800 for that one too).... cool part is didn't have tow hook so someone drove from mbsd to give me one so I could get towed..... hopefully isn't too crazy and hopefully don't have to put any stock parts back on.... Got a slow as hell c300 now with the big old "courtesy of mbsd" on the window....
Old Apr 6, 2009 | 08:38 PM
jicl55's Avatar
2003 cl55 (sold)
Not red.... think it is oil but not sure.... might be oil from the supercharger? Seal right there possibly? Clutch? No oil on the bottom of the car. It looks like it just leaked all over the interior engine parts on the front side. Like I said, they did replace that top pulley (whatever the hell it's called?) cuz my bearings were completely fried last November, so if its that, it would still be covered..... hopefully find out tomorrow... in the meantime
Old Apr 6, 2009 | 08:41 PM
jicl55's Avatar
2003 cl55 (sold)
Originally Posted by ECBAOBAO
+1
White smoke coming from top of that pulley where most of the oil had leaked onto the belt..... right on top under the engine cover.....
Old Apr 6, 2009 | 11:14 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
Looks like a valve cover gasket blew out. If so, it's a cheap fix for DIY. About $80 in parts and 2-hours of labor for DIY. But the dealer is likely to charge an arm and a leg for that job. It's not exactly easy because you have to take off a number of things.
Old Apr 6, 2009 | 11:35 PM
jicl55's Avatar
2003 cl55 (sold)
thank god for extended warranty..... as soon as it is up, I'm going to throw the car away Nah, on second thought, never ever could do that... luv this stupid thing too much..... maybe get my 80mm throttle body put in while I'm there? (still have to get a couple of parts tho..... Mr. Brenton, where r u?)
Old Apr 7, 2009 | 01:07 AM
ECBAOBAO's Avatar
nascar
Hopefully your extended warranty covers whatever happened!
Did you ever get a video of a driveby outside the car? Haha
Old Apr 7, 2009 | 02:42 AM
jicl55's Avatar
2003 cl55 (sold)
Actually, they may not if its a gasket.... we'll see tho, hopefully not too bad.... and no, haven't done the outside vid yet. Thought I'd wait and do the throttle body, then do the outside.... but ain't gonna be doing nothing in the slow *** c300.
Old Apr 7, 2009 | 02:19 PM
AZIPOD's Avatar
Any info from the dealer yet? The more I look at your pic, the more I'm feeling that its an awkward place for oil to be coming out (gasket is on the V cylinders, but your oil is coming out near the SC clutch). But not withstanding a complete failure, I can't see how oil can blow out other than from the valve-cover gaskets.
Old Apr 7, 2009 | 03:23 PM
msheredy's Avatar
MB
What did it smell like? Coolant has a distinctive sweet smell while oil(s) are going to smell like, well, burning oil.
Old Apr 7, 2009 | 04:12 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Supercharger front seal?
Could it be the seal to the input shaft on the supercharger? Am not a expert on these superchargers but if they are like typical Roots blowers (ours is a twin screw), they use gear oil in both the front and rear case. Perhaps this is gear oil from the supercharger? A hot engine would cause the oil to smoke. I had a seal go out on a centrifugal Procharger once and it did something very similar. At least you noticed it. Would be a b*itch to have the blower seize on you.
While on the subject, does MB have a recommendation on changing out the oil in our superchargers, or do they consider it to be "lifetime" as they did with their transmissions for so long?
Best of luck at the stealership, hope this is a minor seal or gasket fix...
Old Apr 7, 2009 | 04:29 PM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
That's a leak on valve cover gasket. W211 is known for having that leak.
You should see some kind of oil on the sides of the valve cover. Replacing the valve cover gasket alone is more than $1k. Its not the parts that is expensive here, its the labor. Alot of things has to be remove before you can even take the valve cover out. I already got mine replace using my extended warranty.
Old Apr 7, 2009 | 05:00 PM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
Sorry to hear that..I hope you got it taken care of without costing you and arms & legs.
Old Apr 7, 2009 | 05:57 PM
jicl55's Avatar
2003 cl55 (sold)
...still no word
Old Apr 7, 2009 | 07:49 PM
AZIPOD's Avatar
What are you smoking?
The gaskets for both banks is less than $80. To remove the valve covers, you have to take off the ignition coils, valve cover bolts, and a few hoses here and there. It's not a easy DIY, but it's completely do able at home with basic tools. It's a 2-hour job.
It can't be $1000 labor to do it. If you are right, then I am surely in the wrong business!
Old Apr 7, 2009 | 08:03 PM
JoelE55's Avatar
I think you should check your source again..Roehl..What kind of gasket is it that cost $1k.? Is it made of gold..? Valve cover gasket runs $25.00 each side..
Old Apr 7, 2009 | 08:10 PM
jicl55's Avatar
2003 cl55 (sold)
Needs new supercharger!
Old Apr 7, 2009 | 08:39 PM
JoelE55's Avatar
That isn't cheap...What did you do to have your supercharger blown out?....ouch!!
Old Apr 7, 2009 | 09:00 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
WTF what happened
Old Apr 7, 2009 | 09:09 PM
jicl55's Avatar
2003 cl55 (sold)
Drive it I don't even take the thing to the track.....
Old Apr 7, 2009 | 09:14 PM
jicl55's Avatar
2003 cl55 (sold)
Originally Posted by shardul
WTF what happened
Some kind of seal in the interior of the supercharger broke that they basically can't get to = need whole new supercharger (think he told me preliminarily $4800 for new supercharger) Should be covered under mb extended warranty (chrysler). Find out more tomorrow.... you know, there is only a couple of more parts to replace and I think I'll have replaced everything Ok, back to my other comment, when this thing is outta warranty, I am gonna throw it away.....
