AMG block build specifications?
Old Apr 9, 2009 | 02:58 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Anyone know where you can find the AMG detailed block build up / assembly specifications? Bearing tolerances, etc. etc?
My STAR CD just does not seem to go into those details.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 9, 2009 | 03:06 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Not a good question, hope all is ok. FYI pistons are available separately now.
Old Apr 9, 2009 | 03:09 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I don't think mb would release detailed specs and tolerences for their motors.
It would be good to know.
Old Apr 9, 2009 | 03:30 PM
PLATINUM SPONSOR
2003 CL55
Originally Posted by Yacht Master
Not a good question, hope all is ok. FYI pistons are available seperately now.
It seems there have been people building motors on this forum with forged pistons. What clearances and bearings tolerances do they go by? Their old stroker Vette build specs from the late 90`s?
Old Apr 9, 2009 | 03:38 PM
bobgodd's Avatar
2004 E55
Why is there so much animosity towards Corvettes around here? Is it engine envy?
Old Apr 9, 2009 | 04:18 PM
PLATINUM SPONSOR
2003 CL55
My thread! I ask the questions here.. Feel free to start a new Vette envy thread though..
Old Apr 9, 2009 | 04:45 PM
bobgodd's Avatar
2004 E55
Touche
Old Apr 9, 2009 | 05:05 PM
ChicagoX's Avatar
W211 E55
Let me ask one of our suppliers if they have more info for you.
Old Apr 9, 2009 | 05:33 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
I have a Technical Data Manual(a rediculiously overpriced book), PM me what info you need, I can get it to you. I do need your engine number though to get the correct info. I can get the number by your vin if you don't know it.
Nick
Old Apr 9, 2009 | 05:44 PM
Max.H's Avatar
E55
Whatcha up to? Sounds interesting... Someone has to have these specs in a service manual or something? If your going to rev the **** out of the motor I would loosen up the tolerances a tad.
I would not run any less then .0015 thousands of an inch oil clearance for the rod bearings and .002 - .0022 thousands of an inch oil clearance for the main bearings.
Old Apr 9, 2009 | 08:16 PM
ChicagoX's Avatar
W211 E55
Originally Posted by nick 55
I have a Technical Data Manual(a rediculiously overpriced book), PM me what info you need, I can get it to you......
Nick
^^^^ That's EXACTLY what you need.
Old Apr 9, 2009 | 08:59 PM
blackbenzz's Avatar
haters crazy
Nick
Would you be able to look up older models such as 01 CLK55?
Old Apr 9, 2009 | 09:40 PM
I am sure you will find the numbers you need, Here are a few bottom end threads to pass the time.
https://mbworld.org/forums/w211-amg/...tons-rods.html
https://mbworld.org/forums/w211-amg/...ine-build.html
Old Apr 10, 2009 | 12:22 AM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Talk to PTE...
His shop in South Florida rebuilt my engine last year and added the VRP cam...He should have some information that might be helpful.
Old Apr 10, 2009 | 06:40 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
I agree with your specs for our engines, but its funny for a Ford 302, the rod clearance was a tad tighter, aka .0008, while the mains were a little loser at .0035 and that was on a cast crank with forged rods.
Neet thread for us engine junkies
See yeah
Old Apr 10, 2009 | 09:43 AM
PLATINUM SPONSOR
2003 CL55
Nick55 , PM sent and the block numbers.
Wow, Thank you all for the info and help.. They way the thread started, I thought this was going to be another top secret topic..
__________________
www.ultimatepd.com
Old Apr 10, 2009 | 10:00 AM
nick 55's Avatar
We here use the Metric system. Leave the inch stuff to Ford.
Nick
PLATINUM SPONSOR
2003 CL55
When you had your engine rebuilt, did you go with stock or custom forged pistons? Did you stay with stock alumisil coated cylinders, or did you have the cylinders re-coated with say Nikasil? Better yet, did you go with some large siamese iron sleeves and custom crank,rods and oversized pistons for a large Litre motor?
It seems a custom large litre motor can cost less than messing with mostly factory MB parts..
At that point, I guess factory specs would be pretty much obsolete..
Old Apr 10, 2009 | 10:02 AM
nick 55's Avatar
Yup, actually, almost all M112 and M113 engines have the same torque specs and tolerences. Let me know what you are looking for.
Nick
Old Apr 10, 2009 | 01:50 PM
Max.H's Avatar
E55
See yeah
Yupp.
Nick
Haha, not quite... The engine builders and machinists I've come across state side use inches for all types of engine bearing clearances. I still use MM frequently though, say measuring a throttle body or cylinder bore. But, for really small stuff reading in thousands of an inch is easier and seems more precise.
Old Apr 13, 2009 | 01:50 PM
PLATINUM SPONSOR
2003 CL55
Nick 55,
You are the man!! 14 pages of detailed specs sent to me,,,is more than helpfull!
Old Apr 13, 2009 | 06:13 PM
Max.H's Avatar
E55
So, what is the factory engine bearing clearances? My guess its little tighter then specs I listed above.
