Kleemann E55 AMG by TTMotorsports
#51
Former Vendor of MBWorld
Whatever we're tuning!
The headers/cat delete really makes the whole package come together.
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Up to ~550chp/~555ctq according to Kleemann with the K1 but I have a couple of in-house mods that I do to the AMG55's that make gains even greater.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#52
'15 E63S wagon
This is probably a newb type question, but how the F does this car pass state emissions/smog tests with no cats? Are the emissions running cleaner (enough to get a legit passing cert?) after the aftermarket tune, or is emissions just something you can overlook in your state?
In California they get very strict about test-only shops and it can be tough to circumvent the system if you have a dirty exhaust car.
#53
2008 A8L, 2002 996TT X50, 2009 X5
As you mention - some states don't even bother to have ongoing emissions testing, but I'd hazard a guess that CA has some Kleemann customers driving around... so I'm not sure how it's worked around.
#54
In NYS OBDII cars are tested/read through the OBDII port inside the vehicle and they look at the readiness of the on-board tests that all vehicles run through when the car is running. As long as the testing facility sees that ALL on-board tests are functioning properly it passes the emission part of the inspection process. If the testing facility would see that there are NO CATS in the car then they will fail the vehicle unless you know people.
The most common way to circumvent the emission on-board tests when you have no cats is the put in O2 simulators or go into the ECU/file and shut off the rear O2's. That is what Kleemann does to correct for the CEL when you install certain headers and run no cats.
SO that is how we F'in get these vehicles to pass! LOL
PS Usually with a performance file the vehicle is running leaner and much more efficiently so the emissions are much lower than the OEM file.
#55
Depends on how they test - it probably would not pass a tailpipe sniffer test (are secondary cats still in place, or have they been removed too?), but if it's just an OBDII check, allegedly Kleemann's software can fool the sensors into reporting that everything is A-OK.
It just finding it in the software that's the tough part!
#56
#57
'15 E63S wagon
TTM--right on, I understand the OBDII check and how that could work.
Since I live in CA and they do a tailpipe sniffer test, how does a cat-delete car pass emissions? The testing shops run at idle, and under load.
I also get that a performance ECU profile will run leaner with less unburned gas in the exhaust...just don't know if it's lean enough.
Does anyone have experience with this?
Finally (sorry for all the q's), what type of performance difference would you look at between a E55 or E63 w/headers/ECU/exhaust/no cats and one with all those mods but WITH cats? Are they that restrictive on the AMGs or is the cat-delete a lower-percentage gain that's more "icing on the cake" than a huuuge gain? I would expect it to make a decent difference (gotta get all that exhaust movin') but not as much of a difference as stock vs ECU/headers/exhaust work.
Obviously I'm interested in getting some of this done to a car in the future
#58
Obviously I'm interested in getting some of this done to a car in the future![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Some software actually uses the fuel to help cool the cylinder so that would probably be too rich and I believe that when it is sniffing the tailpipe they are looking for the maximum emission value hit no matter where in the RPM range it happened.
FI cars need as little back pressure as possible where as NA cars need the pressure to a certain degree. It really comes down to how you drive, track, strip or road course and what other mods you have and of course whether it is a NA or FI car.
Cats are VERY restrictive especially on a FI car but you can still make tremendous gains even leaving the cats in the car for emission/state regulation ans inspection purposes.
Unless you know someone that can pass your car.
#59
