*** 55 Kompressor Heat Spacers Special ***
S600TT, R350
Ladies and Gentlemen:
With summer heat quickly approaching, I would like to introduce the May Special on our intake manifold heat spacers. Our heat spacers isolate intake manifold from cylinder head, reducing heat transfer from the engine block and thus heat soak.
Intake manifold temperatures decrease on average 20-30F. Reduced intake air temperatures help 55s produce more consistent power in hot weather.
We offer both upper and lower sets. Upper set can installed very easily by simply removing stock surge tanks. Lower set requires removal of the blower and is highly recommended when throttle body upgrade is performed.
Upper set - Regular $289, on Special $189 ($100 off)
Lower Set - Regular $289, on Special $189 ($100 off)
Both Sets - Regular $578, on Special $359 ($219 off)
GET THESE!!!
Just a quick note, I have a set of upper surge tank spacers that I got a couple years back from EVO. These things REALLY work and Vadim is showing a great price here. I am definitely getting the lower set when I step up to the bigger TB. The uppers are an easy DIY and you will be glad you have them!!!
Is this the same Vadim from the SHO Shop days? Awesome parts for those cars.
I'm having trouble getting on the website listed in your signature - is it active?
Thanks.
Thanks.
2006 E55 2004 Audi S4 (gone and missed)
Is there any benefit to installing the upper heat spacers on a stock E55, or is it neccesary to have other cooling mods such as CM30 and larger heat exchanger first? in order to see results. I eventually plan on doing a pulley and tune. At $189 these will make a nice fathers day gift from the wife.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
S600TT, R350
Thanks.
Thanks.
Thanks! The website is being built and will be up shortly.
