Is there a benefit to have SS brake lines?
Old May 14, 2009 | 04:40 PM
psuball1's Avatar
04 E55, 12 GL 450(wife)
I was thinking of upgrading my brake lines to SS. Has anyone done this? Is there really any positive benefits if I don't track the car?
Old May 14, 2009 | 04:46 PM
jangy's Avatar
2015 S212
There is good and bad.
In theory, the SS lines are much more rigid than the rubber ones and so do not need to compress and build pressure, making them quicker to respond. Basically, you are sending a hydraulic signal from point a to point b. Liquids do not compress, so the only remaining factor is the housing they are in.
My personal experience with them is that I like the pedal feel better. It is more responsive since the rubber is not there to absorb the vibrations.
Now, our cars only have the hydraulics from the SBC unit to the corners. We are drive by wire from the pedal to the unit. This means two things for us. First, the difference you will notice is less, since you have less rubber to stretch anyway. Second, we have no pedal feel anyway so that advantage goes away.
The bad? I have heard of many SS lines snapping, since they are so rigid. They aren't that expensive and can be done easily so your call.
Old May 14, 2009 | 05:11 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i have them on my cars....
for daily drive, i can't notice a thing...
Old May 14, 2009 | 08:01 PM
psuball1's Avatar
Thanks for the feedback.
I figured that having the SS lines would have positive and negative factors. If I don't plan to track the car I don't see the need. I was curious to see if there are any benefits for daily driving.
Old May 14, 2009 | 09:36 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
I've had SS lines before in a number of cars. No difference if you ask me.
Old May 14, 2009 | 09:39 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Good Explanation
Old May 15, 2009 | 07:42 PM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
SS lines do improve pedal feel, especially on cars with no or very low levels of brake assist from vacuum or hydraulic boosters.
However, there really is no difference to be had on the W211 E55 as Jangy points out. The brake by wire removes any improvement in pedal feel that would be there.
