steering wheel and easy entry problem
(it's stuck in the bottom position) and does not
go up to exit the car
The steering wheel moves forward and back but not up and down...
dammit
I hear the motor trying to adjust but no movement
Soo I turned off the easy entry option soo the motor don't burn out
What up with it????
$11 part and $450 in labor. Thank goodness for the warranty. It's called a coupler. Its in the area of the steering column motor.
Pics of snapped coupler:
http://bayhas.com/mercedes/w211/cont..._dashboard.htm
This project is not for the faint hearted so if you want to tackle this yourself, be honest about your mechanical abilities before you tear into your center console and dash. If you do it yourself, you'll save yourself $400-$500 and know the job was done right. I'm heading to the dealer in the morning to pickup part #2034620678.
Can't wait to have my steering wheel back in the low position, but I will never turn that Easy Entry feature back on again. Too much wear and tear on that tilt/wishbone coupling and risk of breaking it again.
