Reso and 2nd cat removal ... sound?
Old 05-24-2009, 10:08 PM
ygha's Avatar
09 SL63 AMG
Hello ~
I had my reso deleted ... but want some more roaring.
The question is ... how much difference in sound between deleting reso only and deleting both reso and 2nd cat?
Thanks in advance ...
Old 05-24-2009, 10:13 PM
aleksandar1099's Avatar
Mercedes
It is more aggressive, but if you really want the sound, you can go for primary and sec cat delete, and get a tune to take care of the CEL. Or get your mufflers gutted out...
Old 05-24-2009, 10:27 PM
chawkins2001's Avatar
2006 E55 AMG
I got the magnaflow magnapack axel back put on last week and it sounds insane. I did have my resonator deleted with 3" pipes with both cats in place, and it sounds very mean. Very deep with a descent amount of drone but at WOT, it turns muscular and nice and smooth.
Old 05-25-2009, 12:06 AM
Max.H's Avatar
E55
any pics of your exhaust? what tips did you use?
Old 05-25-2009, 02:12 PM
2006 E55 AMG
I used pypes dual stainless steel polihed tips. My car is in the shop getting the kleeman's put on so I will get pics this week. I am also going to do a video clip for you guys. I know that the more hardcore owners like Jakpro, Aleksander and the others after a more aggressive note will like it, but the majority here will say it is WAY to loud and obnoxious.
Old 05-25-2009, 05:33 PM
Max.H's Avatar
E55
I cant wait to hear it!
Old 05-26-2009, 01:08 AM
III II I I AMG's Avatar
2003 e55
i did mine with 2nd delete with resonator replaced with straight pipes, it definitely sounds alot more meaner and louder than just the resonator, but when you first get it, you wont notice a big difference, drive around with it for a good while and ull really start noticing the difference, specially when i drive around in florida's weather, when i drive around for a long time, the exhaust gets alot louder and aggressive
Old 05-26-2009, 01:18 AM
RenntechE55's Avatar
CLS55 AMG 030
I just did Res delete also with Straight pipes but i want more. did you use a H or X pipe III II I AMG? thanks
Old 05-26-2009, 01:37 AM
ECBAOBAO's Avatar
nascar
reso delete won't really get oyu much sound, you're gonna have to either remove the 2nd or prim cats or work with the muffler (either gut or change)
Old 05-26-2009, 01:40 AM
CLS55 AMG 030
Originally Posted by ECBAOBAO
reso delete won't really get you much sound, you're gonna have to either remove the 2nd or prim cats or work with the muffler (either gut or change)
Ya I know my cash flow is a little tight right now and it was a $100 bucks well spent it gave it a lil different sound. Im content for now ,but will be doing 2nd cat delete in September. Has anyone done 2nd cat delete with 200cell primaries? thanks
Old 05-26-2009, 08:55 AM
Serenity Now's Avatar
03 E55 AMG
Been reading exhaust threads for awhile now, but I've not seen responses about what the sound is like if the 2ndary cats are deleted and that's all? I'm really not wanting any drone issues so I was thinking of keeping resonator. Anybody done this? If so was it noticeable at all?
Old 05-26-2009, 10:57 AM
Mercedes
I have had this on my original exhaust, only sec cat delete does nothing!! you have to do res and sec cat to get that nice sound, no drone....
btw, Craig, it can never too loud!!! Well.... if you are bleeding from the ears you might be at that turning point...
Old 05-26-2009, 12:42 PM
Donovan386's Avatar
E55
I was going to get my resonator taken out this weekend. I might as well do the secondary cat removal as well... I want a nice deep grunt so that sounds perfect. I was quoted $200 for the reso delete- that sound about right? How much more should it be for the cat delete?
Old 05-26-2009, 12:53 PM
efivefiveamg's Avatar
2004 E55
I got my reso deleted and replaced with straight pipes for $70, so $200 is way too high if going with straight pipes.
If going with an X-pipe it will be higher depending upon make of x-pipe. I was quoted $125 for reso delete and magnaflow x-pipe install.
Old 05-26-2009, 01:02 PM
1 BAD BURB's Avatar
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
Dumb question, but do you need to re-tune the ecu for hacking out the 2nd cats. i know the resonator would not have an issue with the ecu.
anyone have sound clips of 2nd and reso removed with stock mufflers?
Aj
Old 05-26-2009, 04:59 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
mine has 2nd cat and resonator deleted but not a stock muffler...
Old 05-26-2009, 05:01 PM
jtc55's Avatar
08 E63
Aj
i hope Fr33kn63 doesn't mind me posting these vids. if it's a problem, let me know and i'll delete it
http://vimeo.com/1746831
http://vimeo.com/1757315
http://vimeo.com/4776156
Old 05-26-2009, 05:11 PM
Mercedes
If you leave in the primary cats and only delete the sec cats, you will not need a retune, no CEL comes on...
Old 05-26-2009, 05:12 PM
Max.H's Avatar
E55
That sounds really good. I bet it doesn't drone either. Gotta ditch 2 of my cats for sure.
Old 05-26-2009, 09:56 PM
2004 E55
aleks--i know you know your ish when it comes to our exhaust, but I've heard the opposite.
are you positive the car won't throw any codes if you remove sec cats?
Old 05-26-2009, 11:15 PM
Max.H's Avatar
E55
The secondaries don't have o2 sensors. It's the primaries that will trigger a light.
Old 05-26-2009, 11:18 PM
2004 E55
Thanks, Max. Do you know if we can pass smog here in CA w/out the sec cats? I assume not.
Old 05-26-2009, 11:42 PM
ECBAOBAO's Avatar
nascar
yea we can pass w/o secondary cats
Old 05-26-2009, 11:51 PM
Mercedes
100% no CEL with sec cat removed, my car is running that way right now since i put it back to stock to sell it!
Old 05-27-2009, 12:57 AM
2004 E55
But there is what looks to be a sensor just past the resonator, IIRC.
Won't this sensor throw a code or cause smog issues?
Quick Reply: Reso and 2nd cat removal ... sound?
