Quote:
Ricker- what you're doing now will be great, if you do it- I will follow w/a custom hood/intake system for the e55.
You know ... I'm basing my theory on the engine compartment of a CLS55 ... I hope it's similar to the E55. I see some obvious areas that can be improved very easily. At least in theory.Originally Posted by itsmeek
100% agreed, there are also multiple ways including a bypass filter to prevent this. Also- an open hood dyno in a non-moving car that makes 600ish hp will definitely yield 40ish (not even 10% increase) hp or so vs a closed hood dyno in a moving car. Not to mention he opened up the restrictions on his system as he mentioned. No matter what you guys claim or think an under hood system w/open element will NOT make more power then one that takes from outside air, unless there are other factors at play. It's extremely simple physics- increase efficiency by removing restrictions and decrease temperatures. Perhaps the restriction on rickers car was so great that the loss from hot air was over ridden by the benefit of opening up the airway. Ricker- what you're doing now will be great, if you do it- I will follow w/a custom hood/intake system for the e55.
I don't believe any under hood system will work best. (Not without a custom hood) The factory design is actually very good IMO.
I have chosen to do the entire hood fabrication myself excluding bondo/paint, after speaking w/few highend bodyshop's their faces were
in shock @ my request to cut/add hood opening, to quote another MBW member they looked as if I had a kock growing outt've my forehead
Sometimes weve gotta rollup our sleeves n' get dirty to get what we want
Quote:
No apologies, I have an answer/design for your ideas on cowl induction there's a certain model of car I found that has exactly what we all want. I'll be testing it after hood-fab, the design may be interchangable between cars after some cutting, I already have the pieces ordered.Originally Posted by JustPete
I just want to test/prove my theory ... and then I'll share it. It's the entrepreneur in me. Sorry.
This may be a silly question ... but I don't suppose anyone has any wind tunnel test data on these cars? Knowing where the highest air pressure area is would be somewhat useful.
Quote:
Nope, but I did read on an another Forum most car makers utilize front area by headlights/grill for air-intakes because it is the highest air pressure area on modern import perf-minded vehicles...Originally Posted by JustPete
What materials have you guys used to insulate the underside of airbox? Though it is plastic, it gets considerable heat soak and transfers heat to the air that enters the engine. Cheap reflective aluminum tape will only do so much, and I'm sure there is better stuff on the market.
Max.H
close
- Join DateNov 2007
- LocationSan Diego
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveE55
Liked:39 Times in 38 Posts
Quote:
You mean to tell me that you don't like to cook your airbox and filters on the valve covers? Originally Posted by bbearden
That lining underneath the hood looks like it would work.
OK ... so I've already drawn up a design for a cold air intake hood that doubles to remove engine compartment heat more efficiently.
It's for the CLS55 though. Now I'm stoked to make one.
Maybe I should have saved my money on the extended warranty.
I wonder how much interest would their be in a replacement hood with a cold air system that could be easily installed. I wonder how many of you guys would go for it or is this a one off kind of project?
Wouldn't be cheap. And sure eliminates any stealth factor.
ExploreQuote:
The demand completely depends on the gains.Originally Posted by JustPete
OK ... so I've already drawn up a design for a cold air intake hood that doubles to remove engine compartment heat more efficiently. It's for the CLS55 though. Now I'm stoked to make one.
probably not as much interest as the CLS55 forumOriginally Posted by JustPete
It's for the CLS55 though. Now I'm stoked to make one. I wonder how much interest would their be in a replacement hood with a cold air system that could be easily installed. I wonder how many of you guys would go for it or is this a one off kind of project?
Max.H
close
- Join DateNov 2007
- LocationSan Diego
We should have an official MBWORLD exclusive E55 intake shoot out! With the best track results as the winner. Hmmmm, who's down??
Quote:
But it would work easily for the E55 too. Originally Posted by prodigymb
Just some different lines to the hood. Personally I think the CLS lines work much better for this very aggressive look.
Quote:
I think the gain would be significant for the simple fact that you could push other mods further. It would also go a long way in reducing that heat soak problem.Originally Posted by str8ridin
It would also be an aesthetic upgrade. Like I said ... one thing you can forget about is being stealth anymore.
Oh ... one other thing I'd bet on is it would make the Kompressor whine, very audible.
I'll have an intake shootout, sure. But I have 4 years on my warranty to sacrifice. What you got? So, when do we get a rough draft of what your planning?
Max.H
close
- Join DateNov 2007
- LocationSan Diego
Cool, an intake is not going to blow your motor. So I am not worried about that. I gotta few designs. Just don't have the time right now to get it of the ground. Originally Posted by JustPete
I have 4 yrs as well, CAI mods/hood chops aint gettin' Dealerships blackball stamp, unless your/our filters fail & let in rocks/dirt = KABOOM!Originally Posted by JustPete
I'll have an intake shootout, sure. But I have 4 years on my warranty to sacrifice. What you got? Senior Member
Quote:
My dealer is very MOD unfriendly ... just let them catch me with a custom hood with the MB intake bypassed. Originally Posted by Thericker
They won't change a broken button in the interior.
Quote:
Grrrr .... Originally Posted by Tech-Tune
This is all you get. I'm not posting the system that will make it work under the hood.
DAMN , that pic came out really small! WTF???
LOL, nice- is that a cowl on the bottom for air induction?
Drawing detail is *****e ... Image shack is hacking it. The intake cowl is on the hood. Believe it or not that hood line is about 2" higher than stock.
I had to reduce the image for upload (Over 10mb) but I didn't know it would turn it to crap.
Brother wait'll you see what I found/bought awaiting installOriginally Posted by JustPete
Drawing detail is *****e ... Image shack is hacking it. The intake cowl is on the hood. Believe it or not that hood line is about 2" higher than stock.I had to reduce the image for upload (Over 10mb) but I didn't know it would turn it to crap.
my hoodline will remain unchanged, at least height wise
& w/some finesse it could be installed on ANY E55/63 SL/55/600/65 CLS63/55 CL55 etc...
