How is the intercooler attached to the cooling system?
The Coolant recovery tank and the radiator are not attached to the intercooler in any way?
I am going to change my IC pump. How do I re-fill the system if I spill some coolant during the change?
Seems to me people in warm states should use waterwetter and water alone in the system.
but bleede it by romving the cover out of the nipple ( left to the S/C pully ) untill water is coming out while the engine is runing.
you may need to do the bleeding again after a day or two.
i would do it both ways. the reservoir cap open way and the way mentioned in the pdf doc that i sent you.
https://mbworld.org/forums/3483672-post11.html
