2 Heat Exchangers in series
Old 07-03-2009, 09:33 AM
JustPete's Avatar
CLS55 AMG 030
Originally Posted by jangy
Adding an extra HE to the front will help, but you do need a decent sized reservoir to make a difference, especially if you crank up the flow. EVO Sport uses our power steering units and that is the smallest one I have seen that functions well. I have not seen another kit that does as well with a little one. i am still looking to find something that will fit in the bumper. in front of the radiator but below the actual metal bumper so it won't take up airflow. I'm hoping for at least 2 gallons
If it flows too quickly, it may not have sufficient time to cool in the H/E.
In the reservoir the coolant is under pressure. No cooling effect there at all.
It would be worth testing, but I'd wager time in a large enough heat exchanger (Obviously the larger the better) at stock flow rates is probably best. I'll bet flow rates were tested by MB for the inter cooler itself. So simply feeding lower temp coolant at the factory rate should work very well.
I think the heat trapped under hood is the white elephant in the room. The temps I got were pretty shocking.
Old 07-03-2009, 11:03 AM
Former Vendor of MBWorld
Autoscope's Avatar
E350 Sport & Rs6
Originally Posted by shardul
It looks so tempting. I wish there was someone in the houston area who would be willing to take on a project like this.
You might just have to come visit me!
So, did I read that right, you want to loop another heat exchanger in the series?
As long as the CFM flow is not compromised you will be fine....
Let me know if you need help with logistics or Renntech!
Old 07-03-2009, 11:18 AM
chawkins2001's Avatar
2006 E55 AMG
How do you measure your IAT temps? Do you have a datalogger?
Old 07-03-2009, 02:25 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
yes, i have one of the OBDII scan tools with the live data feature.
Quick Reply: 2 Heat Exchangers in series
