Service D?
This PDF file has the info you need to clear the reminder.
https://mbworld.org/forums/3307806-post1.html
I tried this PDF and I cannot get my E63 to to get past the "service x in xxxx miles" when I hold down the reset button for 5 seconds. Why??
You might be doing it on the wrong display screen. You have to toggle through the screens until you get to the "permanent" Service Message (this is the same message except it doesn't disappear, NOT to be confused with the exact same message which only appears for a few seconds upon startup). Once you get to that screen, hit the reset button for 5 seconds and it will bring you to the menus in the PDF file. Use the "Confirm" option to get rid of the service reminder. This worked on my E55 so hopefully it's the same on a 63.
Glorified oil change, visual inspections and I think they call for brake fluid flush, nothing you can't do at home with proper tools.
Cheers
Cheers
https://www.benzworld.org/forums/1933194-post2.html
https://forums.nicoclub.com/debunkin...r-t180100.html
#33
Maybe Eurocharged?
#34
This is why, we don't take our cars to the dealership. Find yourself an independent Mercedes Shop, that you can trust to perform all your routine services and save your money.
If you don't know by now, this is how the dealerships make their money, thru the services they provide that is more expensive than what an independent shop would charge.
