Heat Wrapping Intake Tubes - Does Work!! (Supporting Data and Pictures)
#52
Former Vendor of MBWorld
C55,SL55,C63
That DEI intake wrap thing looks kinda cool, NPI. A cheaper thing you could do is get some heat tape and try that. It may not look great in the end though. I think you cant get that stuff at Home Depot too. IDK?
Also to confirm these test results. I too wrapped my intake tube on my car and seen a reduction in temp. So it does do something.
#53
Its funny how after 3 pages of posts not a single person has mentioned that this is a completely pointless modification. The airbox & intake tubes are both made of heat insulating plastic, yet sitting right below them is the massive METAL intake manifold. It doesn't matter how much lower the temps are going through the intake tubes & airbox, it is irrelevant because as soon as that air passes through the large maze of a metal intake manifold (which is essentially a ginormous heat sink) then this is completely pointless.
The only real way to lower intake temps is to have the entire intake manifold removed and heated in a true heat resistant cured ceramic coating (not just ceramic based paint). All this is a complete waste of time & money. You are better of ceramic coating your stock intake & exhaust manifolds to control under hood temps than to do things like this. These are ineffective band-aid solutions at best. I do not mean to be blunt, just being honest.
#54
2005 E55 AMG
Pwnt ^^ I thought this was the real ams > http://www.amsperformance.com/
#55
what kind of temp differences can you see with this ceramic coating? and who can do this kind of stuff? cost?
#56
2002 BMW M5, 1992 AWD DSM, 1988 Yamaha FZR1000
Correct me if I'm wrong, but don't these pipes lead to the TB which then leads to the S/C, at which point the air is intercooled, and THEN into the intake manifold? The air will be heated inside one engine component or another regardless, but I don't think that having lower air temps at the beginning of the intake tract is "pointless".
#57
96 and 08 911 turbos
I think the point is that a 10 degree difference in IAT while the hood is open and the car is at a standstill is not going to mean much after its been compressed and then intercooled.
One might argue that more important is cooling off the intercooler fluid.
This is a placebo mod.
#58
C55,SL55,C63
The question is: Is this relative? will a 13 degree drop in temps = a 13 degree drop across the board? Isolated cold air intakes have been around for a long time and basically have proven to work by keeping the hot engine away from the intake.
The cooler you can get the air entering the engine the better performance. I think we all know that.
I tend to think that keeping the heat out and in turn lowering the air temp in the tubes will result in a temp drop at the manifold side. Making the temp drop relative across the board.
Unless the engine quickly heats the air entering, to the engine's internal ambient temp or the max temp the engine can heat the air.
I try to related to.. Why my AC in my house sucks on hot days and work better on cooler days.
Maybe a hair dryer test is in order. Try and read the air temp coming out of a hair dryer out side on a hot day. Then do the same test in an Air conditioned room. Is there any diff in exiting air temps from hot air outside or cooler air on the inside?
I think we need Mr Wizard for this, but sadly he died.
#59
2003 W211 E55, 2003 W220 S600
#60
No,
It won't do anything, its a great gimic but it won't do anything on either NA or FI cars. For NA cars, the intake manifold is after the throttle body & airbox sitting right on top of the engine so all the engine's heat gets absorbed by the intake manifold, so even if the air is coming in 10 degress (or whatever) cooler, its not going to make a difference once it exits the intake manifold (it will still be the same temp). Plastic does a much better job of insulating from engine bay heat than bare metal so the Achilles's heel in the intake system is the uncoated stock intake manifold.
Ceramic coatings will reduce the heat typically by 80-95% depending on the type of coating. In fact, if you coat both your intake & exhaust manifolds, your underhood temps will drop drastically, but you will still have some head (waste heat coming from radiator and a small amount from the motor itself). Also, it is VERY important to differentiate between ceramic based paint, and a true high temp ceramic coating. True high temp ceramic coatings are expensive and difficult to apply without the right machinery. Furthermore, they require a full curing process to be strong which is both materials, labor & energy intensive. There are lots of headers out there being marketed as "Ceramic coated headers" that are really just non-stainless headers with ceramic paint on them (Ebay as well as some higher end header manufacturers). You can easily spot these fakes by their weak fragile coatings which you can scratch off the coating with your bare finger nails, or simply by handling it (etc). A true high temp ceramic coating is chemically bonded to the surface of the header and is very strong. However, even these coatings cannot prevent rust all together (though they do prolong the life of a mild steel header substantially more than ceramic paint coatings).
Heres a rough estimate just to give you an idea, temps measured 1 inch above header surface while engine is running:
![](http://www.thinairpowersports.com/Ceramic/BlackSatinGraph2.jpg)
On FI cars, It makes even less of an impact since any cold air will be heated tremendously due to the compression of the air alone. On FI cars the intercooler is what matters most, the temp of the air coming in the intake itself really doesn't have any impact, its cooling the air post compression that matters most.
My point is not that cold air does not help, obviously it does. My point is that the plastic airtubes & plastic airbox are NOT the problem, its all the other components after them that matter. Wasting time wrapping the plastic components and doing nothing to all the much more heat conductive metal components post airbox isn't going to help you at all. That's like buying 3 McDonald's Big Macs w/ 2 fries and then ordering a Diet Coke... gimme a break lol, the diet coke isn't doing anything. Always address the low hanging fruit first... then move on to the next component.
#62
was the graph meant to be in celsius? if not, room temp is freezing cold down there ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
so ceramic coating the intake manifolds will help out a lot, huh? what kind of cost are we looking at here? and who does that kinda job? and whats the best coating?
and are you suggesting that perhaps heat wrapping the i/c would be beneficial?
#63
Typically black satin ceramic coatings have the highest heat rating (2000-2500F), most others are in the 1500F range. Black would look pretty cool anyways so its not a bad way to go. On the intake manifold make sure they only coat the exterior, no need to do the interior. You could just have the outside of stock manifolds coated as well. Coating process usually in the $150-250 per component on avg (depending on size and how you do it). If you send multiple components to them I'm sure they can give you a discount of some kind. Do NOT coat the SCs... they need to radiate heat outwards and expel heat, it may cause the SC to exceed its normal heat range, but all other components are fair game ( you can even coat pistons & the works but that gets pricey).
#65
Tests must have been done up north in cooler climates I suppose, it was done by some hot rodder magazine (i forget which, but you get the point). Those are accurate, it is F. True ceramic headers are impressive, after running an M3 on the dyno hard I could literally get my hands within 1/2" of the headers for 5-10 sec and it was merely luke warm, do that with a regular set of headers and you are talking serious burns. Nobody does true ceramic coatings for the Mercedes market, however you can always just send off your engine components to Jet Hot and they can do it for you, their coatings are legit.
i dont really wanna coat my SS headers. its a pain as is to install them. i'll just leave them the way they are lol.
#66
Our headers can be ceramic coated as well, but that's up to the customer to do themselves, we don't do it simply due to cost restraints.
#67
2004 E55 AMG
Every little bit helps. A tube of a certain length takes time for air to pass through. The less heated tubing it has to pass through matters. The intake tubes are not a big heat source for the air, but they are a significant length of the air path. heat exposure over time. Wraps are cheap and easy, and don't forget the cool factor of gold wrap that ceramic coatings don't have.
#68
SL55 AMG
AMS...what are your thoughts on Swain Tech coatings? They are supposed to be some of the leading suppliers to motorsport teams. I have a header for a straight six on my race car that was swain tech coated and it's been going strong and keeping very cool since 2004. And it sees 4 hrs a day (road course circuits) in the middle of summer at redline 99% of the time on the race track
#69
1 Post
CLS55 AMG
You guys are putting to much effort into very very small performance gains. A better more effective idea would be to get the inlet points completely out of the engine compartment, and maximize the heat exchangers efficiency. Also you need to be reading the charged air temperature after the heat exchanger.
#70
2005 E55 AMG
Swain tech's white lightning is the sex. ![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
I run this on a few of my turbocharged exhaust manifolds, turbo housings, & down pipes. It is imo the best coating as far as durability & heat suppression. If it can handle turbocharged parts it can handle na headers etc..........
#71
#72
my wife wild, but she loves every minute of it.
#73
1 Post
CLS55 AMG
The supercharger *charges* the air and the heat exchanger cools down the charged air. that's the only temperature that matters. While the cooler the air before the H/E the cooler the air after the H/E is a given. If his H/E is not lowering the air that's being charged by the screws as efficiently as possible he may be just ice skating up hill.
#74
#75
