Heat Wrapping Intake Tubes - Does Work!! (Supporting Data and Pictures)
Old 06-28-2010, 03:30 PM
  #101
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Originally Posted by EcoScope
I am planning to wrap mine too + get the airbox filters insulated with insulation tape too But I don't have tools to test the temperature but definitely if I did both it will change even a little.
There is another idea to insulate heat from the plastic airbox which is creating a layer from below using materials that when dry it makes like cement (hard) layer. It is possible to apply thin layer that would be a good mod.
I am planning to put the high temperature tape on the airbox filters below and up to insulate heat and hoping that will make better performance.
my air boxes are insulated from the bottom.
Old 01-31-2011, 08:05 PM
  #102
MB_Forever's Avatar
E63 P30, CL500 Sport
What happened to the images in your first post? Can you please re-post them?
Old 05-20-2012, 04:17 PM
  #103
Ribo89's Avatar
a Tank
Anyone ever get that data on this mod? Is it worth it. I'm thinking of buying this.
Amazon Amazon
Will cost me only $5(have $40 amazon credit).
Old 05-20-2012, 11:54 PM
  #104
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Applying DEI Reflect-A-Gold tape will eliminate any radiant heating. It should be applied to the intake tubes and the outside of the air boxes. This material is used in everything from rockets to F1 cars. See for yourself - - - apply it to your air boxes and the hold the air box an inch or so above the burner on an electric cook top - - - DON'T TOUCH IT TO THE COOK TOP SURFACE! The material will reflect more than 90% of the radiant heat. DO NOT TRY THIS WITH AN OPEN FLAME!
Heat Wrapping Intake Tubes - Does Work!! (Supporting Data and Pictures)-pa220151italya.jpg
Old 05-22-2012, 01:34 PM
  #105
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
Where can I get this stuff?
Old 05-22-2012, 01:41 PM
  #106
Ribo89's Avatar
a Tank
Here
Amazon Amazon
Old 05-23-2012, 05:35 AM
  #107
jcjmw's Avatar
2005 E55 Wagon
Take a look at this engine pic of the w212
http://www.topgear.com/uk/photos/bmw...-08?imageNo=13
Are the intakes wrapped by the factory?
Old 09-28-2012, 11:33 PM
  #108
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
those arent wrapped with heat stuff, its cloth to absorb residual water that may get sucked through the intake, the 05 c230 with the m271 engine has the same thing
Quick Reply: Heat Wrapping Intake Tubes - Does Work!! (Supporting Data and Pictures)
