S/C pump Fail Poll
Old 08-20-2009, 12:34 AM
Jaybejay's Avatar
2004 E55 AMG--1999 E55 AMG--2007 ACURA MDX--E-GLIDE Electric Skateboard
77000 miles all original. She has a chirp, but kicks in with confidence every time.
Not looking to replace it anytime soon.
Old 08-20-2009, 12:45 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Mine failed within the last month or two, shardul logged the intake temps at 200+ IIRC, it was hot out, mid day Houston summer. I'm at 119K, so if it hasnt been replaced in the past then this might be a new record for a stock pump.
I'm putting in the CM30 and a larger HE this Saturday, thanks to Vadim @ FD.
Old 08-20-2009, 12:44 PM
spudslatte's Avatar
'05 e55, '02 911, and '01 ML320
Mine was DOA at 50K miles when I rec'd the car from FL - replaced with CM30 while headers were being installed
Old 08-20-2009, 01:51 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Just so you know a CM90 will fit in OEM location with a little bracket modification - but only just. Reason I have this biggie is because I have 2 rads in series ... W220 and the CODE3.
I am still wondering which one I should feed first between these two...? Any thots? At mom its the W220 -> CODE3 -> I/C
W220 unit is mounted in front of the A/C heat exchanger.
Next is split circuit and boot reservoir with the CM90.
Quick Reply: S/C pump Fail Poll
