*** FD555 Power Package for 55 Kompressors ***
Any pictures of the 190mm pulley?
__________________
On G55, FD555 still works the same.
The exhaust manifolds are different. I would have to make different H-pipe inlets to adapt HEMs to it. HiFlow 200 cell metal cats and remove resonators. 82 mm TB and you will be around 620-630HP.
I did very similar package on SL55, that will be called FD625. I will post dyno graphs later today.
There is another 5-10HP with 93 octane. All of our numbers are with 91CA.
I also already have two-month-old K&N filters; would I get a little discount if I didn't need new ones?
I guess I'll have to see what the going rate is when I can come up with $2300 + a trip to CA.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
ECU can be programmed to a single octane setting. However, it will work with +-2 points, as stock knock sensors will take care of any fuel variables.
Next level will be adding 3'' MidPipes with an X-pipe, VRP cams and 190 mm damper. I expect power level to climb close to 675 HP. This is very close to what Alan is running now. An addition of External Intercoolers (SLR style) should bring it low to mid 700s. After that the blower is very close to it's airflow limit.
Next level will be adding 3'' MidPipes with an X-pipe, VRP cams and 190 mm damper. I expect power level to climb close to 675 RWHP. This is very close to what Alan is running now. An addition of External Intercoolers (SLR style) should bring it low to mid 700s. After that the blower is very close to it's airflow limit.
What is the e55 stock boost with no mod's at all straight from the factory?
When some one does the FD625 kit what boost will there car run and what pulley size do u use on the FD625 kit?
Can the stock engine (pistons/rods) so on handle the FD625 with every day driving ?
2. FD625 uses 175mm pulley, 190 mm is currently being data logged. I will have more info shortly.
3. Stock engine can handle over 700HP with no problems. FD625 is actually easier on the engine in terms of allowing it to breathe better and to run cooler. AMG builds the engines to run on autobahn for hours at a time at over 100 mph. Which very few of us in US or other countries would be able to get away with and thus load the engine at the same level.
