*** FD555 Power Package for 55 Kompressors ***
Old Aug 24, 2009 | 01:58 PM
  #51
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
Originally Posted by Vadim @ FD
1. Stock boost is 9.5 psi in 3rd, 14.6 psi in 4th.
...didn't know that. does it just bleed boost until 4th?
Old Aug 24, 2009 | 03:51 PM
  #52
Vadim @ FD's Avatar
S600TT, R350
No, 4th has higher load.
Old Aug 25, 2009 | 12:52 AM
  #53
Ohbev's Avatar
E55 AMG Kompressor
So if some one was to do short headers and then the FD175mm pulley. what will the boost go to then in 3rd and 4th
Old Aug 25, 2009 | 01:28 PM
  #54
Vadim @ FD's Avatar
S600TT, R350
You will be down about 1 -1.5lbs. This is why I am making 190 mm. I will have data shortly.
Old Aug 25, 2009 | 07:50 PM
  #55
Ohbev's Avatar
E55 AMG Kompressor
will the 190mm pulley give you some slip coz its so big ?
Old Aug 26, 2009 | 01:14 PM
  #56
prodigymb's Avatar
more detail? since the sc is belt driven so shouldn't it produce same boost at the same rpm regardless of gear.
Old Aug 26, 2009 | 03:06 PM
  #57
Full Throttle's Avatar
CLS55 AMG
Boost is relative to load not RPM.
Old Aug 26, 2009 | 03:22 PM
  #58
Vadim @ FD's Avatar
S600TT, R350
Correct.
Lower gears have lower load.
Old Aug 26, 2009 | 03:49 PM
  #59
CLS55 AMG
Vadim
When can we expect the 190mm pulley and software to be available.
Old Aug 26, 2009 | 05:42 PM
  #60
Vadim @ FD's Avatar
S600TT, R350
175 and 190 share the same damper. The outer ring is what gets changed out.
So if your order 175 mm damper, you can always update it to 190 mm.
I will have more data on 190 mm later next week.
Old Aug 31, 2009 | 06:09 PM
  #61
CLS55 AMG
Vadim is your CLS55 mid pipe something that you keep in stock or will it need to be fabricated?
Old Sep 9, 2009 | 02:30 PM
  #62
Vadim @ FD's Avatar
S600TT, R350
I am making new batch this week. Let me know if you want me to put a name on a set for you.
Old Sep 9, 2009 | 03:36 PM
  #63
ShangoAshe's Avatar
2020 AMG GT-R PRO
still have NOT seen any data regarding your 190mm pulley vadim as promised...
been over 2 weeks, still nothing! i thought you will have the s55 numbers out
Old Sep 9, 2009 | 09:34 PM
  #64
Vadim @ FD's Avatar
S600TT, R350
The client with 190 is on vacation and will be back later next week. As soon as he is back - he goes on the dyno.
Old Sep 9, 2009 | 09:49 PM
  #65
bassn_07's Avatar
2006 E55 AMG
By chance did you get dyno numbers and data log boost pre 190 pulley? Is the 190 pulley the only mod he's adding? If you did could you please post the numbers? I'm really curious what kind of boost gains you'll see. Could you also please post up his mod list.
Thank Vadim!
Old Sep 9, 2009 | 10:00 PM
  #66
Vadim @ FD's Avatar
S600TT, R350
The best part of new pulley design is that client can go from 175 to 190 in under 30 minutes.
I will have data shortly. Thank you for waiting.
Old Sep 10, 2009 | 12:04 AM
  #67
Hammer Down's Avatar
2015 E63S, 2018 E63S
Is it necessary to tune on a dyno or can you go out to the track and log info and tune while on the track?
