E63 Front Pads Change
You'll need a hammer & a small flathead or phillips to remove the top & bottom pins, and a 13mm socket to remove the center brace.
Use tool of choice to push pistons back.
New Pads and Sensor Installed
Back Together Again
After 21,000 miles
I also did mine week before last with OEM (using latest MB part number to eliminate squeaking) pads. Mine weren't as worn as yours, probably about 50%, I just turned 16K on my car. I also flushed/bled the old fluid from the front calipers. The brake pedal is now rock solid, and the car stops RIGHT NOW when I need to. Awesome brakes. Total job took me under an hour.
Thanks for posting for us.
There was also no information I could use to order brake pads other than the stock OEMs.
Here is a great place http://www.placeforbrakes.com/index.php I followed some other recommendations but was only able to find products for the 55.
No problem ordering EBC red or yellow pads right over the net from these guys. They had others but you need to call. They do not carry Porterfield and no one has shown Porterfield has front pads for E63 (they do have rears which are common to previous models).
Since I have a pressure bleeder, I will do the job myself. My understanding is that the bleed order is RR, LR, LF, RF but this is an assumption from a 55 posting.
As for brake fluid, I will stay with stock. The performance is very good in the first place. Castrol SRF is the top of the line AND recommended to me by the Black Series AMG engineers who I met at Laguna Seca. The Castrol web site is very clear about ensuring all other brake fluid be flushed out in order to achieve their stated performance. Also, their fluid only has a 18month life until it must be replaced. Again, info from Castrol.
So I am at 40K and will probably tackle this job in a couple of weeks. Just need to check the rotor thicknesses. I hope they will go another stint.
I will post a DIY with pictures when I do it.
Thanks for the pics and thread..!!
After my session at Laguna, my disks are below minimum. I know this because measured before the event they only had 0.05 inch left and now the slots are starting to fade in places. The car has 75k on it.
I have decided to use
http://www.racingbrake.com/Two_piece...141-381-02.htm
For the front. Not sure on the rears. It is a toss up between stock and evosport. Planning on EBC Yellow all around.
Will get evosport Ti brake shims.
I will not do all this until I prep for another track day. If it was all street I would be good for another 20k.
This is a good old post to revive. The DIY was great.
This way you are not pushing dirty fluid back into the system.
Only open the nipple on the caliper side you are compressing slip the pad in and do the other side of the caliper. 1/2 at a time
