racing in dynomode
Old Aug 28, 2009 | 01:25 PM
c43amgedmonton1
Guest
Posts: n/a
racing in dynomode
i read it earlier in a thread, but the search button isn't working to well for me lately. Im going to the track(drag racing) tonight looking for the best setup.
I plan on going in comfort,raised and in sport mode
My question is has anyone raced in dynomode, if so is it better or worse?
thanks in advance,
Johnny.
Old Aug 28, 2009 | 04:00 PM
siswati's Avatar
'10 Panamera S, '06 AMG CLS55, '07 Miata MX5, '02 MB SPRINTER, '99 Spec Miata Race Car (2X)
IMHO - Always in Dyno mode - it's definitely faster if you know how to get the launch done rite. Left foot brake, let teh light change and if you just care about ET, ignore the light, when you are ready, gently ease on the gas, roll off the line, let the tail squat, and only then do you mash the pedal. Go to the floorboards to soon and you will lose traction instantly and your run will be toast.
In Dyno mode there is no interference from the ESP and have run low 1.7's 60ft in Dyno mode. Never been under 1.81 in normal mode with ESP off (but its never really off)
Old Aug 28, 2009 | 04:04 PM
c43amgedmonton1
Guest
Posts: n/a
Perfect thats what i wanted to hear.
Old Aug 28, 2009 | 04:11 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
I'm also going to da track on Sunday does dyno mode work better with n.a drag radial as well?? Also can some one post on how I'm suppost to get it in and out of dyno mode on here please I saw it in a diffrent post but can't find it?
Old Aug 28, 2009 | 04:49 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
actually, dynomode makes no difference whatsoever. there's no power gained and esp plays no role if you're launching properly. i can run with esp on, off, or in dynomode and run the exact same times as long as i'm getting traction.
Old Aug 28, 2009 | 06:38 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Yep, same here. +1
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 28, 2009 | 08:18 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Plus for a launch ESP off is effectively the same.
The only difference is if you screw up and hit the brakes, you have no ABS and the balance is no good without it. Very rear biased.
Old Aug 28, 2009 | 10:20 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+1, From the foremost E55 launch expert Chiromikey,
need I say more?
Old Aug 29, 2009 | 01:46 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I also agree with Mikey, learn you car and practice, I'm down to 1.81 60' with a 30 series profile (no sidewall flex) 300 treadwear tire (not the softest) I always run with the ESP on!
Old Aug 30, 2009 | 03:35 AM
bassn_07's Avatar
2006 E55 AMG
I have run all my times with ESP on and never once in Dyno mode or ESP off. I ran my 3 best launches back to back with ESP on - 1.659, 1.664, and 1.666. With that said I totally agree with Chiro, it makes no difference except for that little extra piece of mind of having ESP on.
