Head Porting Results
Here are the flow numbers:
Stock:
.100" I:88.7 E:65.7
.200" I:167.5 E:118.6
.300" I:218.2 E:159.4
.400" I:217.8 E:177.6
.500" I:224.8 E:184.3
Modified:
.100" I:101.1 E:71.6
.200" I:195.3 E:117.8
.300" I:256.9 E:164.0
.400" I:296.0 E:192.3
.500" I:318.9 E:199.1
Gains:
.100" I:12.4 E:5.9
.200" I:27.8 E:-.8
.300" I:38.7 E:4.6
.400" I:78.2 E:14.7
.500" I:94.1 E:14.8
8 months behind on this project already..Heads should net us the largest gains yet, since not much room for real cams..
Thanks for posting the results! Nice work and good gains!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Being that our engines are boost enhanced, hitting the magic velocity number is going to take the right key to open the door. I alot of engines formats that just start being ported for the first time, can show poor results. At least until the right porter figures out the combination of flow verses shear velocity efficiency..
Some porters will post high flow numbers (flow makes sales) but net poor hp gains. Others may have less flow but more velocity and show huge gains. The porters we have in Houston, have my confidence to get good gains..
Last time I checked it was going for about $5k for this work and I wouldn't dump that kind of money on something I wasn't sure of gains. Are the AMG heads the same as non AMG heads with some port/polish work?
Last time I checked it was going for about $5k for this work and I wouldn't dump that kind of money on something I wasn't sure of gains. Are the AMG heads the same as non AMG heads with some port/polish work?Our goal for these heads was to maintain max velocity, while still improving flow. I'll post the pics of the stock and ported ones soon, and you can see that there is a ton of material left to be taken out, but just didn't seem necessary given our past experience with these.
Cant wait for pics/results!
FYI- they never made a non AMG 55, that includes my CLK55
I think it would be in your best interest to port your own heads and not to buy non-AMG heads and port them, if that's what you were thinking.
Dude, you have so many mods that I truely believe you'll see gains from porting your heads. But I understand that you would like to see proof in porting before you make that decision. The problem is that your set up is unique and unless someone with your exact set up ports their heads and test them you may never really know.
Just do it!!!
Just do it!!!
I would like to do this but I am currently in the process of purchasing a new property and dont have the spending money to do it. Nor do I know who to trust with a project like this. There are a couple things I have on the list before I get to the head porting. It may be a while lol. Thanks for your help/input
We can do the V8s for 2000.00 including the above services.
We looked into larger valves and titanium retainers and its a bit pricey unless a large amount are ordered. For 99% of the cars a stock valved ported head will be more then enough.
