Widest wheels?
Old Oct 8, 2009 | 01:41 PM
kjlindgr's Avatar
Viking War Ship
Widest wheels?
Hey all. I'm doing some research on wheels for a W211 E55 and am wondering from you experts what the widest rim width is that can be put on an E55. I understand that offset is key for clearance, so details regarding that are also appreciated.
I see most wheel/tire packages using 8.5" widths in the front and 10" in the rear. Is this just the most common or is this the max? Could you bump as much as 10" in the front and 12" in the rear without running into rubbing issues?
Also, what wheels from what other Merc's fit the E55's? Will SL, CL, CLK, etc. wheels all cross over just fine with fender, brake, and suspension clearance or are there just a couple choices that will work?
Any and all help is GREATLY appreciated.
Thanks!!
Old Oct 8, 2009 | 07:36 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Im pretty sure mine are 11.5 in the rear and 8.5 in the front. stock height 285 in the rear..
Old Oct 8, 2009 | 07:42 PM
detail-king's Avatar
Former Vendor of MBWorld
Mercedes Benz CLS63 AMG
The max I have seen are 10.5 in the rear. I tried 11 on my E55 and it did not work, it rubs. Your safest bet without rubbing is 8.5 front and 10 rear. If you want to push it, 10.5 in the rear will work. Really the only other wheels that will work are E-Class regular and S-Class depending on the wheel and thats about it. The SL and CLS and CL and some S-Class are low offset in the rear and will rub for sure.
Old Oct 8, 2009 | 07:52 PM
E55Bullet's Avatar
I changed my mind I do believe mine are 10.5
Old Oct 8, 2009 | 07:54 PM
kjlindgr's Avatar
Viking War Ship
Thanks for the info guys...great stuff!
So as I'm browsing around, wheels that are said to be CL/S compatible will most likely be those low offset ones that will rub on the E, right?
Are there any other popular "between model" wheel swaps out there?
Old Oct 8, 2009 | 08:01 PM
BenzoBoi's Avatar
Super Moderator
W221
What size wheels are you plannin on going with? My first set of HRE's were 20x9F and 20x10R. No rubbing what so ever. My second set of HRE's were 19x9F and 19x10.5R with no rubbing either.
If I'm not mistaken, you can use CLS / SL wheels if you use one size narrower for the tire in the rear.
Old Oct 8, 2009 | 09:07 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
What size tires you running in the rear now?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 8, 2009 | 10:50 PM
RenntechE55's Avatar
CLS55 AMG 030
I think the widest wheels you can run is 9" up front and 10.5" in the rear. Im running a set of wheels that where from a SL Im just using skinny tires the offset is extremely aggressive but no rubbing yet.
Old Oct 8, 2009 | 11:41 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
i have CLS/SL55 wheels on my car, they look the same as the stock E55 wheels but offset and width is different
Old Oct 8, 2009 | 11:54 PM
jangy's Avatar
2015 S212
Correct! 275 is max. Also, there are multiple ets ranging from 27 to 33 for the CLS / SL chassis.
Old Oct 8, 2009 | 11:56 PM
jangy's Avatar
2015 S212
Which SL? If they are currently et33, you can shave 4mm off the inside and they will hold 295s with no rubbing at all.
Old Oct 8, 2009 | 11:57 PM
jangy's Avatar
2015 S212
I want to try 9.5s on the front.
Old Oct 9, 2009 | 12:10 AM
CLS55 AMG 030
They are the OZ wheels I posted a while back , ill have to try and find the offsets
