Premature bearing failure due to pulleys
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 13, 2009 | 05:30 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I just got off the phone with Cory and he advised against installing any pulley larger than 168mm as this will lead to premature bearing failure on the supercharger. The bad part is that you cannot replace just the bearings but must replace the entire supercharger. These factory SCs are hard to find brand new and their are no aftermarket remanufacturers either.
I also learned that the E55 SC is only 1.8litre capacity but because the rotors are hollow they can spin much faster (24K rpm stock) up to 30K rpm with an oversized pulley. The gear ratios also allow for the faster rotation speed. The hollow rotors are more fragile than the solid rotors of other blowers and are another potential failure point.
Has anyone's supercharger with a 180mm or 190mm pulley had bearing failure after extended drag duty and high mileage?
The reason I called Cory is because I wanted to install an OEM E55 blower if it can spin faster than my Kleemann Autorotor twin-screw.
Old Oct 13, 2009 | 05:33 PM
psk145's Avatar
2006 E55
I wonder if this is going to stir up the hornets nest.
Old Oct 13, 2009 | 05:35 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
+1
Wait and watch
Old Oct 13, 2009 | 05:45 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Makes sense that the bearings would wear more spinning faster, but then will it all just be primarily usage (mileage) based? Big question, what's that limit? Kleemann should kinda know the answer, since they made the statement. Or is it simply all theoretical?
Old Oct 13, 2009 | 05:50 PM
AMGSC's Avatar
From what I gathered, it's the heat and friction that increases exponentially as the rotation speed increases.
Old Oct 13, 2009 | 06:10 PM
Karlson's Avatar
06 E55
He told me exactly the same thing couple weeks ago when I asked him about Kleemann why they don't make 172+mm pulleys
Old Oct 13, 2009 | 06:39 PM
Thericker's Avatar
V12-Biturbo
Robert, there's a seller on Ebay that sells remanufactured 55k Blowers
You've come this far, I say spin the sheet outta it! if it grenades replacement around the corner based outt've Malibu, CA $3750 O.B.O.
http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
Old Oct 13, 2009 | 06:50 PM
AMGSC's Avatar
Nice find on Ebay! I just put an offer on it. I may need to consult with Hooley on how to mount this thing if I'm dissapointed with the Kleemann Autorotor results.
Do you have the remanufacturers contact info? Maybe other E55 owners know where to look but maybe not.
Old Oct 13, 2009 | 06:59 PM
Thericker's Avatar
V12-Biturbo
It's in the link, but turns out this is a BRAND NEW unit in listing bidding starts @ $3750 OBO chk out small print below add
1 ) This offer is for a brand new original Mercedes Supercharger
Never Installed , and in original Mercedes Box Retail over $ 7,825.00
This is not a rebuilt or after-market , this is a brand new original AMG / Mercedes Part !
a rebuilt is $ 4,500.00 plus your core !
MBZ Part NO A1130900580 / VB94001301 O4O113092L
Mercedes No on outside Box A113 090 02 80 subsided by the New A1130900580 Part No.
For more info please e-mail or call ( 310 ) 457 1709
Old Oct 13, 2009 | 07:22 PM
jmf003's Avatar
'03 SL55
If you asked the engineers at AMG, they would say any pulley size larger than 154mm leads to premature failure. And they should know: they designed the engine! If the 168mm pulley was perfectly safe, they'd have used it instead of the 154mm.
Bottom line: if you want the longest lived supercharger possible, stick with the AMG pulley. A larger pulley will necessarily shorten the supercharger life. The larger the pulley, the shorter the life.
Old Oct 13, 2009 | 07:29 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
It is kind of a general statement that could be applied to any mod or even driving a car fast.. Most mods create more wear and tear on a car, just like driving them hard. Super charger is damn cheap compared to the amount of tire wear I get from my 180mm pulley..lol
Plus1 on spinning the hell out of everything!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 13, 2009 | 07:40 PM
hooleyboy's Avatar
C55,SL55,C63
I've recently contacted Whipple, one of the techs there who I was talking with via email, feels the AMG supercharger can be fitted with Whipple's internals. I don't think anyone has done it, But it might be worth looking into.
Maybe Autoroter can fit some cool parts to your kleemann blower?
Old Oct 13, 2009 | 07:48 PM
TopGun32's Avatar
if that was to happen to me..
i would use my auto club to tow me back to my garage, hire my mechanic to remove the pulley, put the stock piece and call the auto club to take me to the dealer.
Chrysler Warranty!
Dealers don't care how you raped your car, as long you have extended warranty.
So far Chrysler has paid $5k out of their end.. and I'm still making payments on the $3200 for a 3 year unlimited miles.
The same thing is said about turbo cars.. too much boost.. ect..
Old Oct 13, 2009 | 07:56 PM
220S's Avatar
That's understandable. No doubt there are MB white papers on tolerances with all their components.
fwiw, here's a PSE rebuilder, and looks like they use better bearings(?) Seems like if they can replace bearings, somebody else should be able to.
http://www.superchargersonline.com/p...SE-MBZ-AMG-E55
Still kinda pricey, but a lot less than OEM.
Old Oct 13, 2009 | 08:02 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i've been running a 178-180mm pulley for just short of 100k miles (125k on the car now). i have had my s/c clutch go out due to bearing failure but that bearing is a $17 replaceable part. i'll let everyone know if my s/c bearing ever goes out.
Old Oct 13, 2009 | 08:14 PM
AMGSC's Avatar
That is a Magnacharger replacement blower which is a roots design and is vastly inferior to the AMG OEM blower.
Old Oct 13, 2009 | 08:22 PM
AMGSC's Avatar
Got you but why is 168mm OK with Kleemann but nothing bigger? There just might be a threshold limit where the bearings begin wearing out abnormally.
btw...I just bought that brand new SL55 blower and will keep it in my garage as a backup blower to my Kleemann.
Old Oct 13, 2009 | 08:27 PM
blackbenzz's Avatar
haters crazy
I was told the reason Kleemann switched from autorotor chargers to eaton is because autorotor went out of business
And yea, spin the charger to its efficiency and not past it! At a certain point you will be making so much heat that its counterproductive. Are you seriously gonna not boost the crap out of it because of premature bearing failure? Come on man, almost anything that makes more power will lead to premature part failure. What is your goal? I think you are getting way ahead of yourself. If my car can run tens on ~7.5PSI do you understand how rediculous 25PSI is (if the charger is even efficient at those levels, which I seriously doubt)? This isnt a 4banger, its a 5.4L V8!
Old Oct 13, 2009 | 08:30 PM
220S's Avatar
Wasn't sure, though maybe it was an OEM rebuild. Still seems like somebody could rebuild it, but Cory should know for sure.
Anyway us N/A guys don't know nuttin' about superchargers anyway.
But good info and a good read.....
Old Oct 13, 2009 | 09:18 PM
cahiil55k's Avatar
My previous Eaton M90 supercharged car had a 3.7" stock pulley. I ran a 2.8" pulley from 92,000 miles until 170,000 miles. It's far from the same supercharger in our AMGs but it had no issues when I sold the car.
Old Oct 13, 2009 | 09:37 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i read somehwere tha the E55 Supercharger is a 2.2L while the C32 unit is a 1.8L. just tried looking for the source page but could not find it ...will look more later.
Old Oct 13, 2009 | 10:49 PM
bassn_07's Avatar
2006 E55 AMG
Haha...exactly, leave it stock if you are worried about premature wear. I modded my car knowing that I'm not going to get the same amount of life out of my engine as stock. Modding is expensive and you must be willing to pay to play...period.
hooleyboy's Avatar
C55,SL55,C63
+1
I wonder if you could get some stuff from kenne bell?
Old Oct 13, 2009 | 11:22 PM
jangy's Avatar
2015 S212
That is a blanket statement that is in the grey zone. As has been asked, why 168 and not 175?
As mentioned, you pay to play. Honestly, I am starting to wonder if a stage 5 should run a 178mm. It may be that we need better cooling. The reason I ask is that there are many EVOsport / RennTech cars that are very fast with 168mm pullies. I am dying to see data from the guys converting from 168mm to the 178mm and see what they think. You listening, Terence?
Last thing, The 55k is 2.3L. At least one car has shown that the AMG SC makes more power than the Kleeman SC. Isn't that what this is really all about?
Old Oct 14, 2009 | 12:42 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Any reciprocating component’s load increases at the square of its speed. It’s simple physics.
AMG’s IHI-sourced supercharger bearings are available from selected aftermarket sources when their replacement owing to excessive wear is, in fact, deemed necessary. Any such trivialities ought to be the furthest thing from your mind at this point during your build, AMGCL65. Know you’ve a substantial bankroll to fund your quest for speed. Get the bloody thing roadworthy first – and only then worry about conquering its potential ancillary hardware longevity demons. Crank pulleys are easy enough to have your technician swap in order to finalize its boost.
All due best wishes of course, but you’ll likely have several far more pressing challenges which need to be addressed long before then.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
