Made my Carbon fiber airbox fit the 82mm TB
Old Oct 23, 2009 | 03:52 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I know this does not go out to the masses but it can be done .. I had a 80mm Carbon fiber air intake and used a die grinder to slowly grind the diameter out to fit the 82mm TB. About 3MM had to be removed. The wall thickness is still plenty thick after the modification. I used my 82mm TB to fit test, as I took material away. After the fit was close, I came back with a sanding wheel bit and rounded/smoothed the final fit.
Took about 20 minutes and fits tighter than any stock Y pipe!!
PS, will post pictures later but short time time right now..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 23, 2009 | 04:09 PM
blackbenzz's Avatar
haters crazy
Nice
Old Oct 23, 2009 | 04:25 PM
RenntechE55's Avatar
CLS55 AMG 030
Im might be doing the same thing soon post pics. thanks
Old Oct 23, 2009 | 08:44 PM
PLATINUM SPONSOR
2003 CL55
Here is a shot of the tools. Star wrench on the coordless to take the air box screws out (duh). Grinding bit and sanding bit to smooth out final fit. I also used some 80 grit hand sand paper to smooth rough edges. Last, used a water hose to wash out intake and then scrub dry with rag..
For the the best seal, take your rubber gasket out of the mouth of the 80mm Y pipe and reverse it. Then slide over the 82mm TB before putting the CF intake on..
Attached Thumbnails Made my Carbon fiber airbox fit the 82mm TB-100_5309.jpg   Made my Carbon fiber airbox fit the 82mm TB-100_5310.jpg   Made my Carbon fiber airbox fit the 82mm TB-100_5307.jpg
__________________
www.ultimatepd.com
Old Oct 23, 2009 | 10:29 PM
CLS55 AMG 030
my CF intake is made for a stock TB you think it can be done for a 82mm TB?
Old Oct 25, 2009 | 09:03 AM
PLATINUM SPONSOR
2003 CL55
I think that may be to much of a stretch but you will have to mic it first..
__________________
www.ultimatepd.com
Old Mar 25, 2014 | 03:44 PM
nysid2007's Avatar
08 E63 AMG
Hey , I know its a really old thread
but just wondering how did you make you own CF air box,
it looks clean ~!!
Old Mar 25, 2014 | 04:36 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
it looks clean ~!!
I'm guessing he is running Carbonio's box or something similiar.
http://www.carboniodirect.com/MB_AMG...z-amg55-ab.htm
Old Mar 25, 2014 | 04:49 PM
nysid2007's Avatar
08 E63 AMG
Silly me, I see ~~~
