New Personal Best + Photos of OEM 16" MT Drag Setup
Wheels: 16x8 OEM Mercedes offset 36, with 5mm spacer -> total offset 31
Tires: 255/50/16 Mickey Thompson ET Street
No rub anywhere, even when the car is lowered. This setup worked out awesome. Grip off the line is amazing, next time hopefully I will crack 11.3 or maybe even high 11.2 if I can get the 60' down to a 1.6-1.62.
Dam fast
Wait till the Mod bug hits you.Awesome tire set up.
Nice Prod, there are a few MB OEM wheels out there you just have to look for them. They may not be as light but they can still get the job done at a fraction of the cost.
-Evosport 175MM Pulley Set
-Evosport Phenolic Intake Plentum Spacers
-Evosport Headers
-LET Custom Ecu Tune (Dyno Tuned) 520whp / 540wtq
-Slowmotion Custom Dual Air Intakes w/ DEI heat shields
-CM30 Supercharger Intercooler Pump
-Code 3 / Spearco Heat Exchanger
-Seamless Motorsports custom dual 3" Exhaust with X-Pipe
-Custom trunkmount icebox
not sure exactly what car the wehels are off of, but i know its a 211 e class. i got them off the car so i will post some part numbers....
i turn it off .....but with these tires it wouldn't matter since there was no spin on the 11.4 runs. even if you have it off and you see it kick in even a little bit .....that should tell you that the run is not going to be clean.
well they are 16s with alot of sidewall so when they are at 19psi they feel a bit sloppy.....nothing to serious. when they are inflated normally they drive fine.
