Famoso SL55 Record Run 10.89 @ 127.51 (Dyno Sheet, Time Slips, Pics, Etc.)
Old 11-24-2009, 04:25 PM
URnext's Avatar
SL55 AMG
Thanks Guys for all the comments
Old 11-24-2009, 04:32 PM
URnext's Avatar
SL55 AMG
Originally Posted by nlpamg
damn! congrats, Sal!
so tell us more about your car. the conversion into the new style and the matte white look incredible.
Thanks! The conversion was a pain in the ash. Pretty simple if you are dealing with the right people, but unfortunatley I didnt.
The color is called Ballon White from Lamborghini it's a Matte White Pearl.
Old 11-24-2009, 04:51 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Very nice string of 10`s and 60 ft times! Very impressive display and doumentation of runs!!! Those tire wrinkles are just plain sick on the Sl55 Benz Flagship..
Any video?
I know you have cams but are your heads ported now as well?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 11-24-2009, 05:13 PM
URnext's Avatar
SL55 AMG
Any video?
Thanks Bro.
I do have a couple of video's but I have to edit them because the filming wasnt too great and there was a lot of filming of the floor.
No cams in yet because there wasnt enough time before this event, but I did have plans on installing these cams right after the event. Now these plans on installing my cams are on hold because Jeremy@Powerchip advised me to hold off on the cams install until I work on my fuel injectors and/or fuel pressure since I am starting to run out of fuel on the top end already and the cams will only make matters worse. So it looks like my stock fuel injectors is the next hurdle I will have to overcome in order to further mod.
As far as head porting is concerned, I dont have any plans on doing this since I dont see any hard data out there that I've seen to prove gains.
Old 11-24-2009, 05:16 PM
jmf003's Avatar
'03 SL55
Yes! Way to go!!
If you don't mind my asking, what PSI and launch technique worked best for you?
Old 11-24-2009, 08:18 PM
Sunir's Avatar
SL55 AMG
WOW Sal congrats man!!! You set the bar high indeed sir looking forward to possibly following in those big footsteps...I'd be interested in the PSI and launch techniques as well as John mentioned above...planning on using that advice at MIR to improve my times
once again...Bravo, well done Sal!
Old 11-24-2009, 09:48 PM
  #32
bassn_07's Avatar
2006 E55 AMG
Originally Posted by URnext
Alan Im coming for that AMG Flag!
You know where I'll be this weekend brotha...bring it on !
Old 11-24-2009, 11:54 PM
  #33
URnext's Avatar
SL55 AMG
Originally Posted by juicee63
SAL,
WOW
Your car looks like an SL65 Black and it ran like one as well.
I would like to thank you for participating and showing us all what is "possible" in a luxury cruiser.
Outstanding work by all involved, this car looks and performs a very difficult combo.
AN AMAZING ACHIEVEMENT BRO
LOL Thanks Bro! Let me know when you will like for me to remove your driver side seat. Now let me work on getting that flag back to So Cal.....
Originally Posted by MB_Forever
Sal, you've done it again my friend..... a million congrats for breaking the record and setting the bar so high
Just three weeks ago, I remember talking to you and you mentioning the possibility of not being able to make it to Famoso I said no way.... we will get this done and because of your hard work and dedication, it happened
What makes this even more of an accomplishment is the fact that traction was not "optimal" due to the rain the morning of.... however, you hooked like crazy Your 60' time is just You kept adapting and ajusting your launch, burnout, etc.... until you did it. Again Excellent work
Just remember..... this is only the beginning
Thanks again Mo for the event. Also thanks for the pep talk a few weeks ago when I told you I might not make it to the event and giving me that extra push.
Old 11-24-2009, 11:58 PM
  #34
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Absolutely incredible. As others have mentioned, that tire wrinkle is Congrats on your achievement. Nice to see so many 55K's in the 10's off nitrous Now that E and SL are out of the way, who's going to do it with an S or CLS?
Old 11-25-2009, 12:11 AM
  #35
URnext's Avatar
SL55 AMG
Originally Posted by jmf003
Yes! Way to go!!
Thanks guys. Believe it or not my first run of the day, which netted me 1.62 60', I was at 34 psi since I completely forgot to adjust the psi when I got to track.
After that I lowered it to 25 lbs since I was hooking well and didnt want to break anything.
In regards to my launch technique, I really do not know how to explain it. I change my launch technique on every run and so far that works for me. I take into consideration if track is cold/hot, how well I hooked on the previous run, and other things come into play as well.
Thanks again guys and cant wait for your results from this coming event.
Old 11-25-2009, 12:16 AM
  #36
moparrbust's Avatar
2005 Crossfire SRT-6
Awesome job and killer 60's...................you're running the same little Hoosiers I run on my Crossfire(but only get 1.7x 60's due to much less power).
Old 11-25-2009, 03:30 AM
  #37
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Oh crap. I just got my Mickey T's today from Summit Racing. Now I hear see that Hoosiers may have been the better choice? Going to check prices of Hoosiers from Summit, Jegs and TireRack before I hit the sack.
What Hoosier tires to the 55Ks run on this forum? A6, R6 or something else? Should I run the same 255/50/16 tires as the Mickey T's?
Old 11-25-2009, 09:11 AM
  #38
c32AMG-DTM's Avatar
All due respect, you're overthinking this a bit. The quickest/fastest cars have run either Hoosier or M/T for their DRs... and usually the same 255/50/16's that you already have. Burn up the ones you just got, and if you don't like them, give the Hoosiers a try. Not A6 or R6, those are auto-x and road-course respectively - you'd want the DRs.
Old 11-25-2009, 09:19 AM
  #39
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
That launch is just sick! Congrats. I love the SL63 front clips swap by the way.
Old 11-25-2009, 12:17 PM
  #40
Fantasm's Avatar
Car Whore
Post a vid, I just wanna hear the sound
Old 11-26-2009, 11:50 AM
  #41
jmf003's Avatar
'03 SL55
Thanks for sharing the info. 24 PSI seemed to work best for me but I haven't tried enough runs at other pressures to decide if that really was the sweet spot. LOL at the 1.62s 60' at 35 PSI.
I've always had the best luck launching off idle then rolling into the throttle (the Chiromikey technique) but am always interested in hearing from people who have had success with other techniques.
Again, sensational runs! You've done a great job setting up your SL55!
Old 11-26-2009, 12:26 PM
  #42
CLK FAN's Avatar
2000 CLK 3.2
I found this on another thread
http://www.youtube.com/watch?v=RAtuDRDApWI
Old 11-26-2009, 09:00 PM
  #43
URnext's Avatar
SL55 AMG
Thank bro, great find.
Old 11-27-2009, 09:17 PM
  #44
BMS
Former Vendor of MBWorld
BMS's Avatar
2018 C63 Sedan
Wondering why this info was not posted on the SL55 site. Just curious.
Old 11-27-2009, 10:54 PM
  #45
RacerX0911's Avatar
damn... congrats
Old 12-01-2009, 10:07 AM
  #46
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Great Run! Congrats! Mods??
Old 12-01-2009, 02:46 PM
  #47
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Very impressive runs, congrats.
Old 12-01-2009, 04:10 PM
  #48
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
i told ya the hoosiers were good too. you did not go wrong with mickey thempsons though. they are a tried and true setup and are good for low 1.6 and high 1.5 sixty foots. like Brett said, go thru these and then get Hoosiers ....see which work best on your car.
btw Hooley used the hoosiers on his C55 and i believe he said he prefers the MTs. as far as i remember he had good results with both.
Old 12-01-2009, 09:43 PM
  #49
bassn_07's Avatar
2006 E55 AMG
I'll let you guys know after this weekend. I'll have Hoosiers mounted on one and MT ET street radials on the other set. Both theses tires will be 16" CCW rims.
Old 12-02-2009, 11:28 AM
  #50
BENZGal's Avatar
Location: school west coast-Summer Internships Va and Bmore
E55 (for sale if the right offer comes along)...too many others to list
Sal,
Way to go buddy! Your car is a true monster and I love the new look. VERY HOT! Sorry I missed you guys this event. I am going to try and make it to the next one and if I can't I will get someone to drive her. Tell Eddie to modify his beauty and get to the track.
Quick Reply: Famoso SL55 Record Run 10.89 @ 127.51 (Dyno Sheet, Time Slips, Pics, Etc.)
