Stage 2 Eurocharged e55 11.514@122.90 with the esp on,124.9 mph traps with esp off
Using 100 oxygenated octane race fuel over pump 91 I'll see .3-.4 leaner conditions with the race fuel. BTW...this is at the track and not on a dyno.
. My point is that I can't tell you what my car would do on your track and yours on mine, unless of course we ran on both. The fact is....we run where we can and provide time slips from these runs. Could Sac be inaccurate....NHRA says it's within spec
. Either way it's the only track that has TnT all year around and open on Saturdays. Have you ran at different tracks to see how your car performs? I've ran on several here in California but only two of them are with my current mods.
Let's also bring up what has already been stated before in the fact that the TWINS, your car and mine, ran at Sac and the So Cal track on the same days. The difference with your car between both tracks was the same difference with mine. People who bracket race their cars also qualify at Sac a lot and end up running at other tracks. I'm sure someone would have ntoiced if it was off. Every track has range but I don't see Sac being off any different then other tracks. It just has great conditions to run in, is Fontana off because times are so slow? Is it short? It's well know the conditions are bad and in turn you have slow times. Sac just has great conditions, weather wise that is at least haha.
This is really important info for me 'cause my E55 only goes 115 in the quarter and I want to know if something's wrong with it
Posts: 71 Quote:
Originally Posted by Hammer Down
Do you still have the slip?
Why,do u think I am lying?
Car also ran 7.48@96 in the 1/8 on a different track.Most tracks around are 1/8.
__________________
2005 e55 Eurocharged 180mm pulley,Eurocharged heat exchanger and pump,LET custom tune,and alot more to come! 532/607 to the rear wheels on a Dynocom dyno.33rwhp and 47ftlbs from a custom Eurocharged/LET dyno tune! 11.5@122.9 on a crap track,next mods will be tb
1000's of posts might impress some,to me,it shows some dont have a life along with a clue.
So you ran 7.48@96 mph STOCK
And now with the following mods in cold air
1.75 60ft
11.514@122.90 mph
7.4@96.25 mph
Based on this your car lost power from your stock 119.5 in 95 degrees and your 7.48@96 stock 1/8th mile time.
Either that or YOU LIED about trapping 96 and 119.5 in 95 degrees.
Case closed
