Major problem $$$$$
04 E55 470 whp
Major problem $$$$$
I noticed a oil leak on my concrete driveway. Called my neighbor (Service Advisor for the last 10 years.) We brought the car in and he brought me back to show me the issue. The aftermarket pulley system had left a gap in the crank, seeping oil. This is not covered under warranty and they will have to put back to stock. Anybody else ever have this issue?
My neighbor is giving me discounts on parts and labor to lessen the blow.
CLS55 AMG 030
What parts need to be replaced? who installed the pulley? You should send the pulley back to where ever you bought it from and have them check it out for you.
I haven't had this issue, but have only been driving with a 180 for 5000 miles or so. Also, my pulley is from a different manufacturer, not sure if that makes a difference. It would suck to have to go back to stock though, especially if you're tuned for a 180. Hope it all works out ok.
04 E55 470 whp
I bought the car with mods from an owner on this forum. MB told me that the pulleys and belts need to be removed to see where it was leaking from first. They used a mirror stick and saw where the leak was but could not confirm. They removed them and that is when they showed me where it is leaking. I am not an MB tech but I trust my friend. He told me that the way the mod is set up is not exactly how the stock sits inside the crank. This tiny space difference caused the oil to leak. So, no choice but for them to repair by using stock parts.
CLS55 AMG 030
04 E55 470 whp
It was from chawkins. MB, explained it was that it does not have a seal. The stock set up is a perfect fit and does not require a seal. the modded set up can be a #$%& hair off, which causes the leak. I will know more tomorrow on the exact parts but I know the pulley set up is needed to replace to stock.
I don't know if this will help you much, but I did have an oil leak before modding the car. It never puddled, but my mechanic said it was worn out seals at 55000 miles. I hope MB isn't just trying to get you to pay for something by blaming it on the mods. Good luck.
CLS55 AMG 030
No it for sure has a front crank seal i have one sitting in my garage that I never had to use. Just post up what they tell you tomorrow.
04 E55 470 whp
I would probably think the same way but my service advisor for the last ten years and is also my neighbor/drinking buddy.
04 E55 470 whp
04 E55 470 whp
04 E55 470 whp
CLS55 AMG 030
I dont think you should go back just yet until you know what the exact problem is. Its not just about loosing power its about how your car will run with it not being tuned properly. I think it will be running rich if you go back to 158mm pulley which is better then lean but I think it wont be fun to drive.
CLS55 AMG 030
04 E55 470 whp
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
CLS55 AMG 030
Like I said just wait and see what they say needs to be replaced. Then maybe send the pulley to Eurocharged to be inspected then you they should be able to tell you if its a bad pulley.So then you would know if its a bad install or just a bad seal.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
how long did the previous owner have the pulley on for and also where did he install it at?
take some pics of the pulley and seal when you go to the dealership.
2004 Ran SRT-10,2007 S550,2016 E400c
Im with emoving and renntech on this have them tell seal failed... the only seal that has anything to do with the pulley is the crank seal which are know to go bad. I have put countless pulleys on cars every kind kleeman,renntech,evosport ect!!! and i have never had a pulley leak that couldnt be fixed. By design the crank seal can be installed at different depths to acount for groves in the pulley. and also they make repair seals if needed. Something dosent seam right in what there telling you.
This makes no sense you could never have metal on metal SEAL.. metal on metal is concidered a bearing or bushing with need constat oil flow....i call
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
CLS55 AMG 030
Yep I thought the same, Hey Brunoboxer PM me your address I will send you the extra seal cause I have no need for it.
Yeah this doesn't add up. The pulley would never be designed to touch the seal. The seal is static and the pulley rotates so if they were too close you could cause excess wear on the seal, but there should be a gab and the amount of that gap (unless its too close) shouldn't cause the seal to fail.
I don't think your neighbor is trying to screw you, but dealerships naturally blame aftermarket parts when something happens. I would think its possible the seal could have been nicked during install.
