check your larger pulley for wobble!
Old Dec 13, 2009 | 09:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
This has been posted before but I was curious and tested a wobbling 175mm VRP pulley.. Have to be tons of them out there.. I had a balance shop and machine shop that specializes in automotive pulley balancing check the wobble issue..
I have heard members being told that it is ok for a pulley to wobble at idle and that with RPM it will smooth out.. This is flat out BS and an optical illusion that is causing damage to your 48K motor.... If it wobbles, it is tearing main bearing apart and causing all kinds of harmonic balance damage. Our outer S/C ring on our crank pulley is pretty far out past center and any wobble is amplified from this extra leverage..
I included a picture of the VRP pulley for example, as it is in this style dsign that is causing wobble. Not sure how many MFG`s use this style and there are ways to make it work but the VRP did not display any.. At least the one i had checked (only 6 months old)..
First the pulley in the picture is made from a stock Mb pulley and that is a plus. (IMO).. Bolt on outer ring is also nice but here is where it all went wrong..
First, the pulley is not balanced (no balancing holes).. This is part of the issue .. Not sure if it was save money or just missed in the design.. Second, it is alsmost impossible to bolt an outer ring onto another ring with multiple holes and stay true.. It will always have some elipse to it , unless the parts are machined to inner lock and then bolt together.. This design failed to have that and thus wobbling pulley`s and stress on seals, bearings, crank and all internal rotating parts..
Check those pulley`s!
Attached Thumbnails check your larger pulley for wobble!-vrp_55_pulley-1-.jpg
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 13, 2009 | 09:29 PM
skratch77's Avatar
2005 E55
my 180 wobbles and iv been waiting for a new one.
Old Dec 13, 2009 | 09:58 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Brooke, are those alignment pins or did the button heads shear off?
Old Dec 13, 2009 | 11:02 PM
PLATINUM SPONSOR
2003 CL55
That picture came off their site. Pic. is not of the one I tested.
Looks like pins but they are still the same as drilling holes.. You have tolerance issues and end up with elipse shape.. Some may be round/true but the odds do not favor a drilled and none balanced part..
__________________
www.ultimatepd.com
Old Dec 13, 2009 | 11:08 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Would have to agree, I passed up a few sales on pulleys due to wobbles. Thankfully the sellers were honest enough to state this in our communication-sure did save the hassle of any Paypal disputes. How much to balance out a wobbly pulley?
Old Dec 13, 2009 | 11:27 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
This is the beauty of remaining stock. So who makes the best pulley? I'm not talking power but build quality.
Old Dec 14, 2009 | 12:45 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
ASP are good.
my pulley is done the same way as stock but it is bigger.
they use the OEM inside pulley and bolt, but remove the outside pulley and get a bigger one. welded the same way as stock is. rubber and etc.
ni wobble @ all.
Old Dec 14, 2009 | 12:58 AM
bassn_07's Avatar
2006 E55 AMG
I 2nd the ASP pulley. I have zero wobble with my pulley and I'm very pleased with the gains. I agree 100% with Brooke on this one, a wobbling pulley is very bad and the result could be catastrophic if unlucky.
Old Dec 14, 2009 | 01:24 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
RennTech
Old Dec 14, 2009 | 02:10 AM
jdj27x's Avatar
RENNTECH / KLEEMANN FTW
Old Dec 14, 2009 | 03:20 AM
BenzoBoi's Avatar
Super Moderator
W221
+3 No wobble for me either...
Old Dec 14, 2009 | 03:29 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
Mine has no wobble at all --- I got lucky --- Afterwards, I heard the Evosports are great because they never wobble -- maybe because they are built from the ground up -- not a stock pulley with a glued on ring.
Old Dec 14, 2009 | 08:07 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
If you're talking build quality and not necessarily power production (as the question was posed above) I'd have to agree 100% with this statement. I've had three crank pullies on my car - only the stock and Kleemann pullies show zero wobble from idle on up. From comments I've seen, I'd surmise Renntech to be in the same boat - although haven't tried their product personally.
Exotic Metal - good info above, thanks for posting.
Old Dec 14, 2009 | 10:10 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
Evosport has no wobble
Old Dec 14, 2009 | 11:45 AM
PLATINUM SPONSOR
2003 CL55
Correct, I was only posting about wobble and not power gains.. Many people do not know or really have time to learn all the dynamics of our harmonic balancing S/C pulley.. I was not picking on one brand or another , just saying to CHECK your aftermarket pulley..
I have only used ASP pulley`s on my cars and SUV`s.. None have ever failed or wobbled and that is why I keep going back to them for all my vehicles`s pulley`s.. I am sure others have had simulair experiences with their favorite pulley.. Either way, just make sure they run true.. I hear that 8-10 thou. of run out is ok but that is still really tight..
Oh yeah, I have also been hearing that ASP has been making some huge custom S/C pulley sets for the 55 S/C engine.. Must be a bunch of sneaky MB members out there..lol I am thinking of going larger pretty soon too. Others may stay quiet but I will post my results, after I go larger..
Old Dec 14, 2009 | 02:28 PM
prodigymb's Avatar
please do tell
i did hear that they made a 190mm for an E55
Old Dec 14, 2009 | 02:36 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
What kind of tool would you use to detect wobble besides your eyes? lol Would a decent shop be able to do this?
BTW Thanks for the pulley Brooke!
Old Dec 14, 2009 | 03:52 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Dial measure to check the wobble
Old Dec 14, 2009 | 05:08 PM
320 dreamer's Avatar
2003 porsche 996 turbo
theres a guy who has a 192 crank pulley on his srt-6 3.2 litre s/c engine. 7 mm bigger than the biggest 185 made!
Old Dec 14, 2009 | 05:30 PM
URnext's Avatar
SL55 AMG
Those sneaky guys........BUSTED
I've talked to Lee a couple times and I was actually entertaing the idea of testing out a bigger pulley and having them make it for me but I was out of time and most likely they werent going to have it ready for me by the Famoso event that past.
I really do wonder what sizes those sneaky MB owner acutally went with and the results they had. I look foward to your result's Brooke
Old Dec 15, 2009 | 01:02 PM
PLATINUM SPONSOR
2003 CL55
Sal, LMAO!! Been hearing of some 185- 195 mm range so far.. I saw several (big mm) in person but names were not given to protect the guilty..
Anyone find any crooked pulley`s in thier recent inspection???
__________________
www.ultimatepd.com
Old Dec 15, 2009 | 03:28 PM
Lopes80's Avatar
E55 AMG
I'm checking my Kleemann this weekend, just in case.. I may actually go to a 180mm sized pulley if i don't get the results I am after from my current/forthcoming mods...
Paul
